1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: pvxs Access/list problem
From: "Heinz Junkes \(FHI\) via Tech-talk" <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 11 Nov 2025 13:55:42 +0100
It seems to be an RTEMS issue. I have tested it extensively on Debian and OS X.
Everything is going as expected. Sorry for the noise here.
I need to take a look at what the problem is with RTEMS.
Danke Heinz
> On 10. Nov 2025, at 21:07, Heinz Junkes via Tech-talk <[email protected]> wrote:
> HI,
>> On 10. Nov 2025, at 17:17, Michael Davidsaver <[email protected]> wrote:
>> On 11/10/25 1:34 AM, Heinz Junkes (FHI) via Tech-talk wrote:
>>> Unfortunately, reading the PVs doesn't work either:
>>> (base) hactar:~ junkes$ env |grep EPICS_PVA
>>> EPICS_PVA_ADDR_LIST=141.14.128.12
>>> EPICS_PVA_AUTO_ADDR_LIST=NO
>>> (base) hactar:~ junkes$ pvget rtems:aiExample
>>> Timeout
>>> rtems:aiExample (base) hactar:~ junkes$ pvget my:custom:pv
>>> Timeout
>>> Does anyone have any idea what I'm overlooking?
>> Are you able to ping the IOC (141.14.128.12) from this host (141.14.128.70)?
> (base) hactar:~ junkes$ ifconfig en0
> en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
> options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
> ether 38:f9:d3:09:e8:15
> inet6 fe80::14bb:5995:e241:143e%en0 prefixlen 64 secured scopeid 0x4
> inet 141.14.128.70 netmask 0xfffff000 broadcast 141.14.143.255
> nd6 options=201<PERFORMNUD,DAD>
> media: autoselect (1000baseT <full-duplex,flow-control>)
> status: active
> (base) hactar:~ junkes$ ping gonzo
> PING gonzo.rz-berlin.mpg.de (141.14.128.12): 56 data bytes
> 64 bytes from 141.14.128.12: icmp_seq=0 ttl=64 time=0.264 ms
> 64 bytes from 141.14.128.12: icmp_seq=1 ttl=64 time=0.295 ms
> 64 bytes from 141.14.128.12: icmp_seq=2 ttl=64 time=0.404 ms
> ^C
> --- gonzo.rz-berlin.mpg.de ping statistics ---
> 3 packets transmitted, 3 packets received, 0.0% packet loss
> round-trip min/avg/max/stddev = 0.264/0.321/0.404/0.060 ms
>> Can you connect to TCP 5076?  eg. with:
>>> telnet 141.14.128.12 5075
> (base) hactar:~ junkes$ telnet 141.14.128.12 5075
> Trying 141.14.128.12...
> Connected to 141.14.128.12.
> Escape character is '^]'.
> ���� anonymousca
>> Also, you might setup a PVA link on this IOC with a distinctive PV name, then use 'pvxvct' on the host to look for those search broadcasts.
> rrtems@rtems-dev:~/MVME6100_7/EPICS/epics-support/pvxs/bin/linux-x86_64$ ./pvxget my:custom:pv
> Timeout with 1 outstanding
> leads to :
> rtems@rtems-dev:~/MVME6100_7/EPICS/epics-support/pvxs/bin/linux-x86_64$ ./pvxvct -P my:custom:pv
> 2025-11-10T21:05:52.932458937 INFO pvxvct 141.14.131.228:39384 Beacon 0x0d5dc20423f82d6367a9991d 141.14.131.228:42479
> 2025-11-10T21:05:56.103177244 INFO pvxvct 141.14.128.65:36209 Searching for:
> 2025-11-10T21:05:56.103207467 INFO pvxvct   "my:custom:pv"
> 2025-11-10T21:05:56.103213055 INFO pvxvct 10.1.2.3:36209 Searching for:
> 2025-11-10T21:05:56.103215518 INFO pvxvct   "my:custom:pv"
> 2025-11-10T21:05:56.291459974 INFO pvxvct 141.14.128.65:36209 Searching for:
> 2025-11-10T21:05:56.291488184 INFO pvxvct   "my:custom:pv"
> 2025-11-10T21:05:56.291494840 INFO pvxvct 10.1.2.3:36209 Searching for:
> 2025-11-10T21:05:56.291505468 INFO pvxvct   "my:custom:pv"
> 2025-11-10T21:06:03.523642481 INFO pvxvct 141.14.136.101:44036 Beacon 0x412ce9bbb99971c4925b7f98 141.14.136.101:5075
> 2025-11-10T21:06:04.212423500 INFO pvxvct 141.14.135.248:60008 Beacon 0x3d28c96800000000332cf600 141.14.135.248:5075
> ^C2025-11-10T21:06:05.395957864 INFO pvxvct Done
> Danke, Heinz
Fwd: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Re: pvxs Access/list problem Michael Davidsaver via Tech-talk
Re: pvxs Access/list problem Heinz Junkes via Tech-talk
Prev: Re: caget: Identical process variable names on multiple servers J. Lewis Muir via Tech-talk
Next: Fwd: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: pvxs Access/list problem Heinz Junkes via Tech-talk
