On 11/11/25 8:47 AM, Heinz Junkes (FHI)
via Tech-talk wrote:
It must have something to do with clock synchronization/NTP
(that's my guess).
Immediately after booting, when NTP is not yet synchronized,
pvlist and pvget PV work, for example.
Can you check to see if the RTEMS network configuration changes?
Also, could you set the $PVXS_LOG environment variable in RTEMS
prior to IOC startup? Before the registerRecordDeviceDriver call?
epicsEnvSet( "PVXS_LOG",
"pvxs.iface*=DEBUG" )
In an effort to handle changing network configuration changes,
PVXS will occasionally re-query the list of local interfaces.
This has long been the case, however I did recently make a change
to _when_ this happens.
With logging enabled, you should see lines like "Ignoring
interface" and "Found interface":
2025-11-12T17:05:54.458712015
DEBUG pvxs.iface Ignoring interface 'lo' address family=17
2025-11-12T17:05:54.458719705
DEBUG pvxs.iface Ignoring interface 'wlp0s20f3' address
family=17
2025-11-12T17:05:54.458721909
DEBUG pvxs.iface Ignoring interface 'br0' address family=17
2025-11-12T17:05:54.458723705
DEBUG pvxs.iface Ignoring interface 'tap0' address family=17
2025-11-12T17:05:54.458746937
DEBUG pvxs.iface Found interface 1 "lo" w/ 2 127.0.0.1
2025-11-12T17:05:54.458794954
DEBUG pvxs.iface Found interface 3 "wlp0s20f3" w/ 2
192.168.169.88
2025-11-12T17:05:54.458805716
DEBUG pvxs.iface Found interface 4 "br0" w/ 2 10.127.127.1
2025-11-12T17:05:54.458821577
DEBUG pvxs.iface Found interface 1 "lo" w/ 10 [::1]
2025-11-12T17:05:54.458835767
DEBUG pvxs.iface Found interface 3 "wlp0s20f3" w/ 10
[fe80::c136:44be:4935:b3e8]
%3
2025-11-12T17:05:54.458875297
DEBUG pvxs.iface Found interface 4 "br0" w/ 10
[fe80::9453:55ff:fe80:63a1]%4
- Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
- Fwd: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Re: caget: Identical process variable names on multiple servers Michael Davidsaver via Tech-talk
aiopvxs Python library available Mike Smith via Tech-talk
<2025>
2026
Re: pvxs Access/list problem Heinz Junkes via Tech-talk
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
