1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Streaming from quadEM to HDF5
To: "[email protected]" <[email protected]>, Graeme Winter <[email protected]>
Date: Wed, 19 Nov 2025 15:19:48 +0000
Hi Graeme,
By default, the quadEM IOC does not load an HDF5 plugin.  It does load a netCDF plugin, and I just tested streaming with that, and it works fine.
My list of things to do in quadEM is to change the IOC and medm screens so that it loads all of the commonPlugins from areaDetector.  That will include HDF5.  I will try to do that today, test it, and add it to the documentation.
Last week I did add a section to the documentation about how to do scanning using the TetrAMM as the detector in 4 different modes.  The current range on all 4 channels can be set independently, so it can be used to collect from up to 4 ion chambers or photodiodes, for example.
From: Tech-talk <[email protected]> on behalf of Graeme Winter via Tech-talk <[email protected]>
Sent: Wednesday, November 19, 2025 8:57 AM
To: [email protected] <[email protected]>
Subject: Streaming from quadEM to HDF5
Good morning / afternoon / day
I promise I have had a look at the documentation but did not achieve enlightenment!
Does someone have a guide someplace or some pointers on how to steam data from quadEM to HDF5 (or some other file) over a longish timeframe
My requirement is to record 4 channels on a BPM through a TetrAMM at e.g. 10kHz for maybe minutes at a time
I am certain that the answer involves some plugin configuration but I feel I may have stumbled into “advanced EPICS” without seeing the warning sign
Appreciate any pointers
For the record, getting the device working with EPICS and reading out (incl. FFT etc.) was a dream and it seems to work very nicely
Thanks in advance and all the best Graeme
Re: Streaming from quadEM to HDF5 Mark Rivers via Tech-talk
Streaming from quadEM to HDF5 Graeme Winter via Tech-talk
Prev: Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Next: Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Streaming from quadEM to HDF5 Graeme Winter via Tech-talk
Next: Re: Streaming from quadEM to HDF5 Mark Rivers via Tech-talk
