1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: pvxs Access/list problem
From: "Heinz Junkes \(FHI\) via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 19 Nov 2025 16:04:06 +0100
Ok, I applied the patch from Chris
remotes/kiwiIOP/chris/close-optional-on-ref-count
Then the correction from SEB
remotes/seb/rtems-6-fix-libio-iop-ref-count
and that is the result at the moment :
RTEMS Shell on /dev/console. Use 'help' to list commands.
erSHLL [/] # r: fcntl: Bad file number
err: fcntl: Bad file number
err: mve0: set_mtu: Bad file number
err: no valid interfaces found
warning: no interfaces have a carrier
err: poll: Bad file number
err: BSD Program: Could not close file 24 or could not remove it from list of open files
err: BSD Program: Could not close file 23 or could not remove it from list of open files
err: BSD Program: Could not close file 22 or could not remove it from list of open files
Heinz
> On 19. Nov 2025, at 03:26, Michael Davidsaver <[email protected]> wrote:
> On 11/14/25 8:21 AM, Heinz Junkes (FHI) wrote:
>> I have now narrowed it down a little further (hopefully)
>> When I boot the target and use the debug messages, I get a constant stream of events:
>> When I now display pvlist on another host, I see the target (141.14.128.12):
>> (I can repeat this several times)
>> (base) hactar:~ junkes$ pvlist
>> GUID 0x0224EB2FE0ED7782E367B71A version 2: tcp@[ 141.14.128.12:5075 ]
>> However, when I run pvlist with GUID, the debug output on the target stops immediately:
>> on the client:
>> (base) hactar:~ junkes$ pvlist 0x0224EB2FE0ED7782E367B71A
> When in "guid" mode, pvlist first sends a UDP discovery ping (same as the no argument case), then opens a TCP connection if it receives a reply with a matching GUID.  So the network traffic of the preceding should be the same as:
>> pvlist
>> pvlist 141.14.128.12:5075
> If a TCP connection is the trigger, you could try to open a connection with eg. "telnet" or "netcat" and see if the UDP traffic stop coincides on TCP connect or disconnect?  Or maybe you have to send some bytes?
Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Fwd: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Re: Fwd: pvxs Access/list problem Michael Davidsaver via Tech-talk
Re: pvxs Access/list problem Michael Davidsaver via Tech-talk
Prev: Streaming from quadEM to HDF5 Graeme Winter via Tech-talk
Next: Re: Streaming from quadEM to HDF5 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Next: Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
