1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: pvxs Access/list problem
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Heinz Junkes (FHI)" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 18 Nov 2025 18:26:04 -0800
On 11/14/25 8:21 AM, Heinz Junkes (FHI) wrote:
I have now narrowed it down a little further (hopefully)
When I boot the target and use the debug messages, I get a constant stream of events:
When I now display pvlist on another host, I see the target (141.14.128.12):
(I can repeat this several times)
(base) hactar:~ junkes$ pvlist
GUID 0x0224EB2FE0ED7782E367B71A version 2: tcp@[ 141.14.128.12:5075 ]
However, when I run pvlist with GUID, the debug output on the target stops immediately:
on the client:
(base) hactar:~ junkes$ pvlist 0x0224EB2FE0ED7782E367B71A
When in "guid" mode, pvlist first sends a UDP discovery ping (same as the no argument case), then opens a TCP connection if it receives a reply with a matching GUID.  So the network traffic of the preceding should be the same as:
pvlist
pvlist 141.14.128.12:5075
If a TCP connection is the trigger, you could try to open a connection with eg. "telnet" or "netcat" and see if the UDP traffic stop coincides on TCP connect or disconnect?  Or maybe you have to send some bytes?
Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Fwd: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Re: Fwd: pvxs Access/list problem Michael Davidsaver via Tech-talk
Prev: Re: pvxs Access/list problem Michael Davidsaver via Tech-talk
Next: Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
