1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Manta G-235B Camera
From: Steven Hunt via Tech-talk <[email protected]>
Date: Mon, 24 Nov 2025 14:40:34 -0800
Thanks, I'll check it out.
On Mon, Nov 24, 2025 at 2:35 PM Mark Rivers <[email protected]> wrote:
Hi Steve,
  • In the past (pre-vimba)  we had  cam1:TriggerDelay - although hardly ever touched it - is that PV still valid?  if so what are the units?
My Manta G-507C camera has these camera-specific PVs that come from the camera features XML file:
(base) [epics@corvette db]$ grep -i delay AVT_Manta_G507C.template
record(ai, "$(P)$(R)GC_TriggerDelayAbs_RBV") {
  field(INP,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_D_TriggerDelayAbs")
record(ao, "$(P)$(R)GC_TriggerDelayAbs") {
  field(OUT,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_D_TriggerDelayAbs")
record(ai, "$(P)$(R)GC_StrobeDelay_RBV") {
  field(INP,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_I_StrobeDelay")
record(ao, "$(P)$(R)GC_StrobeDelay") {
  field(OUT,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_I_StrobeDelay")
record(ai, "$(P)$(R)GC_FraStaTriDelay_RBV") {
  field(INP,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_I_FrameStartTriggerDelay")
record(ao, "$(P)$(R)GC_FraStaTriDelay") {
  field(OUT,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_I_FrameStartTriggerDelay")
It looks like the first one (TriggerDelayAbs) probably corresponds to the TriggerDelay you previously used with ADProsilica.
The time units for all GenICam features are microseconds.
  • Also tried cam1:ShutterOpenDelay and cam1:ShutterCloseDelay .....  never used these in the past, not sure how they are used, and what choice should be made to cam1:ShutterMode to make use of them?
The cam1:ShutterOpenDelay is generally used with external shutters that are controlled by EPICS PVs.  It is a part of ADCore.  It can also be used with detectors that have mechanical shutters controlled by the vendor API.  I don’t think it is useful in this case.
Sent: Monday, November 24, 2025 3:59 PM
Hi Mark,  thanks ....
Best regards
On Mon, Nov 24, 2025 at 1:47 PM Mark Rivers <[email protected]> wrote:
Steve, please be specific about what PV you are referring to.  Do you mean $(P)$(R)ShutterOpenDelay, $(P)$(R)ShutterCloseDelay, or some other PV with the string “delay” in it?
From: Tech-talk <[email protected]> On Behalf Of Steven Hunt via Tech-talk
Sent: Monday, November 24, 2025 2:01 PM
To: tech-talk <[email protected]>
Subject: Manta G-235B Camera
Hi, can anyone explain the usage of delay for Mantra cameras using the vimba driver?  the EDM screen says units are seconds - is that correct?   I  set this to a value that should not acquire the beam, but it still does so.
Thanks in advance
Manta G-235B Camera Steven Hunt via Tech-talk
RE: Manta G-235B Camera Mark Rivers via Tech-talk
Re: Manta G-235B Camera Steven Hunt via Tech-talk
Prev: RE: Manta G-235B Camera Mark Rivers via Tech-talk
Next: Get notified of alarms internally to IOC w/o requiring record fields David Bracey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
