1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Alarm stuck in "Async in progress" even after record processing is fine
From: Marco Filho via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, EPICS Tech-Talk <[email protected]>, juremalovrh <[email protected]>
Date: Thu, 27 Nov 2025 08:10:30 +0000
Hi, Andrew, Jure
Thanks for the explanation, I will test with latest EPICS versions and see if it works.
Searching for
DBR_PUT_ACKT I now managed to find some documentation about it also 🙂
Best regards,
Marco
Sent: Wednesday, November 26, 2025 19:55
To: Marco Filho <[email protected]>; EPICS Tech-Talk <[email protected]>
Hi Marco,
Acknowledging an alarm with the IOC won’t clear the AMSG field. As Jure wrote, there was a bug in the handling of that field which has been fixed in EPICS 7.0.9.
If you’re still curious about the ACKT field, there are three type codes DBR_PUT_ACKT, DBR_PUT_ACKS and DBR_STSACK_STRING plus associated data types provided by Channel Access and the CA client library to globally acknowledge alarms inside the IOC. Unfortunately the PVA protocol doesn’t implement anything like these though, so if you’re using PVA (since you also asked about AMSG) you can’t store your alarm acknowledgement states in your IOCs. The CA operations were used by the old Motif-based Alarm Handler client, but the newer alarm systems implemented for CSS/Phoebus keep their own alarm acknowledgement database. I don’t think they can use the CA acknowledgement mechanism at all.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 11/21/25, 9:19 AM, "Tech-talk" <[email protected]> wrote:
Hi, all.
I'm not sure if this is a bug or a feature: I have an IOC that hangs the record processing when the hardware disconnects. This causes the record to process over itself more than ten times, generating an "Async in progress" alarm message.
When the hardware finally reconnects, the record processing gets back to normal again, but the alarm message never disappears. AMSG and NAMSG keep displaying "Async in progress". ACKT is YES and ACKS is INVALID, although SEVR is already in NO_ALARM.
Shouldn't AMSG go to an empty string? Is there a proper way to acknowledge this alarm?
I found in the documentation:
"The ACKT field specifies if it is necessary to acknowledge transient alarms."
But I couldn't find how is this acknowledgment made.
Thanks for any help,
Marco
Alarm stuck in "Async in progress" even after record processing is fine Marco Filho via Tech-talk
Re: Alarm stuck in "Async in progress" even after record processing is fine Johnson, Andrew N. via Tech-talk
Prev: Re: Alarm stuck in "Async in progress" even after record processing is fine Johnson, Andrew N. via Tech-talk
Next: RE: Asyn record CNCT field does not update Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Manta G-235B Camera Steven Hunt via Tech-talk
