1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Asyn record CNCT field does not update
To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Nov 2025 19:20:10 +0000
Hi Abdalla,
Are you using a drvAsynIPPort driver to handle the UDP communication?  If so, then when I look at the code here:
https://github.com/epics-modules/asyn/blob/e2a281e22b4d84ba51e56428959c2dfa506a8312/asyn/drvAsynSerial/drvAsynIPPort.c#L799
then it appears that the disconnectOnReadTimeout option also works for UDP connections.  If you set that option to Y then it will call closeConnection(), which will call pasynManager->exceptionDisconnect().  Your driver does not need to worry about that.  If autoConnect=1 then your driver will be called trying to reconnect.  If it succeeds you can call asynPortDriver::connect().
  • Does implementing the connect() give correct feedback on the CNCT field?
Yes, the CNCT field reflects the status of the exceptionConnect() and exceptionDisconnect() calls.
  • It would be great if you share existing drivers implementing the connect() method.
There are not many drivers that handle that directly, because most use drvAsynIPPort which takes care of it for  them.
Sent: Thursday, November 27, 2025 11:21 AM
To: Mark Rivers <[email protected]>; [email protected]
Subject: Re: Asyn record CNCT field does not update
Hello Mark
What I meant is that I set autoConnect to 0 and handle it manually why doing IO, I thought that is how autoConnect works.
Does implementing the connect() give correct feedback on the CNCT field? It would be great if you share existing drivers implementing the connect() method.
Thanks
Abdalla.
Sent: Thursday, November 27, 2025 7:41:24 PM
To: Abdalla Ahmad <[email protected]>; [email protected] <[email protected]>
  • Should I set autoConnect to 0 in case I want to implement a connection logic in the driver? Or it does not matter in this case of UDP?
I suggest setting autoConnect=1 and implementing the connect() method in your driver.  Then asynManager will call your driver periodically to try to connect.  If your driver finds that the device is available it then calls the asynPortDriver base class connect() method, which calls pasynManager->exceptionConnect().
Or were you thinking of some other connection logic in your driver?
Sent: Thursday, November 27, 2025 2:14 AM
Hi Mark
Thanks for the info. Should I set autoConnect to 0 in case I want to implement a connection logic in the driver? Or it does not matter in this case of UDP?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
Email : [email protected]
Website: www.sesame.org.jo
Sent: Tuesday, November 25, 2025 8:58 PM
Hi Abdalla,
Sorry, I missed the fact that you are using UDP, not TCP.  In that case there is no permanent connection established between your driver and the device.  Each UDP read or write operation is completely independent.  Your driver will need to implement the logic which might be, for example, after 5 unsuccessful I/O attempts call pasynManager ->exceptionDisconnect() to tell asynManager that the device is disconnected.  Since you have set autoConnect=1 asynManager will periodically call the connect() method in your driver.  If your driver finds that the device is available, it then calls pasynManager->exceptionConnect().
From: Tech-talk <[email protected]> On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Tuesday, November 25, 2025 11:37 AM
To: [email protected]
Subject: Asyn record CNCT field does not update
Hi
I developed an asynPortDriver to control a device through UDP, I want to use asynRecord CNCT field to monitor the port connection state whether the device is connected or not. The driver is configured with auto connect flag set to 1. When I monitor the field and disconnect the device, I get error message indicating IO error, but the field does not change to disconnect. I am I missing other settings to be done?
Best Regards,
Abdalla.
Asyn record CNCT field does not update Abdalla Ahmad via Tech-talk
RE: Asyn record CNCT field does not update Mark Rivers via Tech-talk
RE: Asyn record CNCT field does not update Abdalla Ahmad via Tech-talk
Re: Asyn record CNCT field does not update Abdalla Ahmad via Tech-talk
Prev: Re: Asyn record CNCT field does not update Abdalla Ahmad via Tech-talk
Next: EPICS codeathon at Diamond Mercado, Ronaldo (DLSLtd, RAL, TEC) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Job opening at GSI Zumbruch, Peter Dr. via Tech-talk
