Hello, I'm trying to use the mtca-evr-300rf with the GTX inhibit function, but I can't control the GTX output. Could you offer some assistance? When I run the command, the following prompt appears: #!bin/linux-x86_64/mrf dbLoadDatabase("dbd/mrf.dbd") mrf_registerRecordDeviceDriver(pdbbase) mrmEvrSetupPCI("EVRF","slot=10") Notice: devPCIFindSpec() expect B:D.F in hex Device EVRF 5:0.0 slot=10 Using IRQ 215 FWVersion 0x18200207 Found version 519 Found SFP EEPROM Sequencer capability detected mTCA: Model mTCA-EVR-300 Pul 24 PS 8 OFP 4 OFPUNIV 4 ORB 10 OBack 8 OFPDly 2 CML 2 Kind 0 IFP 58 EVR FIFO task start Enabling interrupts dbLoadRecords("db/evr-mtca-300rf.db", "P=TST{EVRF, ES="}", EVR=EVRF") macLib: macro ON is undefined (expanding string # It will be removed in future versions. Please use evrMrmApp/Db/mrmevrout.db $(ON)FineDelay-SP and $(ON)FineDelay-RB instead. ) macLib: macro ON is undefined (expanding string # It will be removed in future versions. Please use evrMrmApp/Db/mrmevrout.db $(ON)FineDelay-SP and $(ON)FineDelay-RB instead. ) WARNING: 'db/evr-mtca-300rf.db' line 30772 has undefined macros macLib: macro ON is undefined (expanding string # It will be removed in future versions. Please use evrMrmApp/Db/mrmevrout.db $(ON)FineDelay-SP and $(ON)FineDelay-RB instead. ) macLib: macro ON is undefined (expanding string # It will be removed in future versions. Please use evrMrmApp/Db/mrmevrout.db $(ON)FineDelay-SP and $(ON)FineDelay-RB instead. ) WARNING: 'db/evr-mtca-300rf.db' line 30854 has undefined macros mrmEvgSetupPCI("EVG","slot=8") Device EVG c:0.0 Using IRQ 217 FPGA version: 280e0207 mTCA-EVM-300 #Inputs FP:3 UV:16 TB:16 BP:8 EVM automatically creating 'EVG:FCT', 'EVG:EVRD', and 'EVG:EVRU' Found SFP EEPROM Found SFP EEPROM Found SFP EEPROM Found SFP EEPROM Found SFP EEPROM Found SFP EEPROM Found SFP EEPROM Found SFP EEPROM Warning: Recommended minimum firmware 2 version is 207.6, found 207.0 Found SFP Strangeness 00000000 Sequencer capability detected VME 64: Model EVRD Pul 16 PS 3 OFP 8 OFPUNIV 0 ORB 0 OBack 0 OFPDly 0 CML 0 Kind 1 IFP 8 EVR FIFO task start Warning: Recommended minimum firmware 2 version is 207.6, found 207.0 Found SFP Strangeness 00000000 Sequencer capability detected VME 64: Model EVRU Pul 16 PS 3 OFP 8 OFPUNIV 0 ORB 0 OBack 0 OFPDly 0 CML 0 Kind 1 IFP 8 EVR FIFO task start PCI interrupt connected! dbLoadRecords("db/mtca-evm-300.db", "SYS=TST, D=EVG, EVG=EVG") iocInit() Starting iocInit ############################################################################ ## EPICS R7.0.9.1-DEV ## Rev. 2025-07-11T16:00+0800 ## Rev. Date build date/time: ############################################################################ TST{EVRF-Out:FPUV2}Freq:Init-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Freq:High-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Freq:Low-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV3}Freq:Init-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Freq:High-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Freq:Low-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPSFP}Freq:Init-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Freq:High-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Freq:Low-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPCML}Freq:Init-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Freq:High-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Freq:Low-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPUV2}Ena-SP: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18 TST{EVRF-Out:FPUV3}Ena-SP: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19 TST{EVRF-Out:FPSFP}Ena-SP: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20 TST{EVRF-Out:FPCML}Ena-SP: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21 TST{EVRF-Out:FPUV2}Ena-Sel: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Pwr-Sel: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Rst-Sel: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Freq:Lvl-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Pat:WfCycle-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV3}Ena-Sel: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Pwr-Sel: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Rst-Sel: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Freq:Lvl-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Pat:WfCycle-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPSFP}Ena-Sel: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Pwr-Sel: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Rst-Sel: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Freq:Lvl-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Pat:WfCycle-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPCML}Ena-Sel: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Pwr-Sel: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Rst-Sel: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Freq:Lvl-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Pat:WfCycle-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPUV2}Src-RB_: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18 TST{EVRF-Out:FPUV2}Src2-RB_: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18 TST{EVRF-Out:FPUV3}Src-RB_: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19 TST{EVRF-Out:FPUV3}Src2-RB_: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19 TST{EVRF-Out:FPSFP}Src-RB_: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20 TST{EVRF-Out:FPSFP}Src2-RB_: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20 TST{EVRF-Out:FPCML}Src-RB_: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21 TST{EVRF-Out:FPCML}Src2-RB_: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21 TST{EVRF-Out:FPUV2}Mult-I: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Freq:Init-RB: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Freq:High-RB: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Freq:Low-RB: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV3}Mult-I: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Freq:Init-RB: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Freq:High-RB: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Freq:Low-RB: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPSFP}Mult-I: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Freq:Init-RB: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Freq:High-RB: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Freq:Low-RB: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPCML}Mult-I: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Freq:Init-RB: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Freq:High-RB: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Freq:Low-RB: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPUV2}Src-SP: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18 TST{EVRF-Out:FPUV2}Src2-SP: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18 TST{EVRF-Out:FPUV3}Src-SP: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19 TST{EVRF-Out:FPUV3}Src2-SP: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19 TST{EVRF-Out:FPSFP}Src-SP: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20 TST{EVRF-Out:FPSFP}Src2-SP: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20 TST{EVRF-Out:FPCML}Src-SP: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21 TST{EVRF-Out:FPCML}Src2-SP: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21 TST{EVRF-Out:FPUV2}Mode-Sel: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV3}Mode-Sel: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPSFP}Mode-Sel: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPCML}Mode-Sel: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPUV2}Pat:Rise-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Pat:High-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Pat:Fall-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Pat:Low-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Pat:Wf-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV2}Pat:Wf-RB: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2 TST{EVRF-Out:FPUV3}Pat:Rise-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Pat:High-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Pat:Fall-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Pat:Low-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Pat:Wf-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPUV3}Pat:Wf-RB: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3 TST{EVRF-Out:FPSFP}Pat:Rise-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Pat:High-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Pat:Fall-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Pat:Low-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Pat:Wf-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPSFP}Pat:Wf-RB: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4 TST{EVRF-Out:FPCML}Pat:Rise-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Pat:High-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Pat:Fall-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Pat:Low-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Pat:Wf-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 TST{EVRF-Out:FPCML}Pat:Wf-RB: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5 Set EVR mTCA-EVR-300 EVRF clock 124915909.090909 newfrac 160334182 (oldfrac 127812077) Set EVR EVRU EVG:EVRU clock 124916000.000000 newfrac 160334182 (oldfrac 0) Set EVR EVRD EVG:EVRD clock 124916000.000000 newfrac 160334182 (oldfrac 0) iocRun: All initialization complete
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
