1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: mtca-evr-300rf,mrfioc2:failed to find/create object
To: <[email protected]>
Cc: [email protected]
Date: Sun, 30 Nov 2025 00:36:52 +0900
Hi SDH,
When you call mrmEvrSetupPCI("EVRF","slot=10"), you use the default EVR
model (MTCA-EVR-300), which only has 2 CML outputs. For MTCA-EVR-300RF,
you should use
mrmEvrSetupPCI("EVRF","slot=10", "RF")
FYI, the IO of different EVR models are listed here:
https://urldefense.us/v3/__https://github.com/epics-modules/mrfioc2/blob/7ad6b8399dbc4271a23afc57cce30553c4419c37/evrMrmApp/src/drvemSetup.cpp*L194-L250__;Iw!!G_uCfscf7eWS!dz9oOQ6mUXEREDwiLYfmHehW9NBzjMKBqnmN-sOpaIm1vD9_cAbf0t8J8MhyVGdtUgMG5zblNgUrZp4zVatLRw$
Parameter of mrmEvrSetupPCI is here:
https://urldefense.us/v3/__https://github.com/epics-modules/mrfioc2/blob/7ad6b8399dbc4271a23afc57cce30553c4419c37/evrMrmApp/src/drvemSetup.cpp*L716-L730__;Iw!!G_uCfscf7eWS!dz9oOQ6mUXEREDwiLYfmHehW9NBzjMKBqnmN-sOpaIm1vD9_cAbf0t8J8MhyVGdtUgMG5zblNgUrZp6pyaCwGw$
Cheers,
Di Wang (Linac, KEK)
RE: mtca-evr-300rf,mrfioc2:failed to find/create object SDH via Tech-talk
Prev: mtca-evr-300rf,mrfioc2:failed to find/create object SDH via Tech-talk
Next: quadEM R9-6 released Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: RE: mtca-evr-300rf,mrfioc2:failed to find/create object SDH via Tech-talk
