1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: quadEM R9-6 released
To: tech-talk <[email protected]>
Date: Sat, 29 Nov 2025 17:54:38 +0000
Folks,
R9-6 of the quadEM module is now available.  These are the release notes:
  • Added a software driver to get data into the quadEM. It is similar to the NDDriverStdArrays for areaDetector. Thanks to Xiaoqiang Wang from PSI for this.
  • Added support for the SenSiC PCR4 picoammeter. Thanks to Sammy Mosca from STLab for this.
  • Added support for the Sydor T4U electrometer. There are 2 implementations for this:
    • T4UDirect: The quadEM driver communicates directly with the T4U.
    • T4U: The quadEM driver communicates with the T4U via a Sydor program. Thanks to Iain Marcuson from Sydor for these.
  • Supported a variant of the Square geometry, where the diodes are arranged counterclockwise. Thanks to Xiaoqiang Wang from PSI for this.
  • Converted the documentation from raw HTML to Sphinx, published at https://epics-modules.github.io/quadEM.
    • Added documentation about scanning with the TetrAMM
    • Added documentation about streaming data to disk with HDF5 plugin
    • Added documentation about using feedback, with an example of pitch feedback on a monochromator.
    • Improved the documentation about plugins.
  • Converted the release notes from raw HTML to RELEASE.md.
  • Added a Word document of a study of noise with the TetrAMM.
  • Removed support for the APS_EM, since this is no longer available or in use. Note that this changes the enum values for all models, and so the new quadEM.* OPI screens are required.
  • Load ADCore/iocBoot/commonPlugins.cmd for all example IOCs.
    • The Plugins/ menu on quadEM.adl now has the following 3 menu items:
      • QE common plugins
      • QE FFT plugins
      • AD common plugins
    • AD common plugins provides all standard areaDetector plugins including ROIs, HDF5, etc.
    • It is now possible to stream data an HDF5 file, for example. This can be sampling at up to 20 kHz on the TetrAMM.
  • Simplify the autosave files to reduce redundancy.
The code is here:
https://github.com/epics-modules/quadEM
Prev: RE: mtca-evr-300rf,mrfioc2:failed to find/create object Di Wang via Tech-talk
Next: Re: Modbus-TCP "authorization" Виталий Балакин via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: mtca-evr-300rf,mrfioc2:failed to find/create object SDH via Tech-talk
Next: Further OMS PC78 questions James P. Withrow via Tech-talk
