1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Further OMS PC78 questions
From: "James P. Withrow via Tech-talk" <[email protected]>
To: "Peterson, Kevin M." <[email protected]>, Tech Talk EPICS <[email protected]>
Date: Thu, 4 Dec 2025 16:12:07 +0000
Kevin -
Thank you for your response.
    I'm using the following line in st.cmd to load the motor record:
    dbLoadTemplate("motor.substitutions")
    and motor.substitutions contains:
    file "/opt/epics/support/motor/db/motor.db"
    pattern
    {P,     N,  M,      DTYP,           C,  S,  DESC,          EGU,      DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
    {serial:,  1,  m1,  "OMS PC68/78",  0,  0,  "motor 1",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
    Appreciate any input that you may have.
-Jim Withrow
Jim Withrow, Research Support Specialist - [email protected]
NE-CAT, Cornell University - https://necat.chem.cornell.edu
Advanced Photon Source, Sector 24
9700 S. Cass Avenue, Building 436 E001
Lemont, IL 60439
Sent: Wednesday, December 3, 2025 4:35 PM
To: Tech Talk EPICS <[email protected]>; James P. Withrow <[email protected]>
Re: Further OMS PC78 questions Peterson, Kevin M. via Tech-talk
Further OMS PC78 questions James P. Withrow via Tech-talk
Prev: Re: Further OMS PC78 questions Peterson, Kevin M. via Tech-talk
Next: Re: Further OMS PC78 questions Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
