1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Consultation: connecting I2C/SPI devices to network
From: Kuldeep Joshi via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 17 Dec 2025 04:26:06 +0000
 Hello Florian,
I have superficially seen your code for the I2C to CA/PVA module.
I have a quick query regarding this,
you have patched the asyn module due to some issue. Can you please elaborate on this.
If I want to use the asyn module along with Modbus, what will be the issues faced while using this patched module??
Kuldeep Joshi
Date: Mon, 15 Dec 2025 11:30:39 +0100
Message-ID:
        <[email protected]" target="_blank">[email protected]>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Hey Gabriel,
I typically use a Raspberry Pi to readout devices via I2C.
For this task I wrote a small i2c device support module, that uses
Stream Device + Asyn (https://urldefense.us/v3/__https://github.com/ffeldbauer/drvAsynI2C__;!!G_uCfscf7eWS!dYsKvtCymp2YJMjpT9hlV9epBG8rvC8U0HFXjj2UxUg0CSKQmX3WB7Ztk9HxUrleo9Jl6mVuLC1Yale1CcceS7vzniRnZn_gqG4$ )
It does not make the I2C communication directly accessible on network,
but it makes all the data points accessible via CA/PVA through an EPICS IOC.
If you really want to have a I2C to Ethernet bridge, I would most likely
use a RP2040 or ESP32 microcontroller and implement a simple UDP or TCP
protocol exchanging either ASCII or raw "strings" containing the data.
HTH,
Florian
On 12/15/25 10:43, Gabriel Fedel via Tech-talk wrote:
> Dear tech-talk,
> Any experience or suggestion of bringing hardware communicating I2C
> and/or SPI to be accessible on network?
> Maybe even some EPICS integration experience on them ?
> Thanks in advance
Ruhr-Universit?t Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universit?tsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://urldefense.us/v3/__https://paluma.ruhr-uni-bochum.de__;!!G_uCfscf7eWS!dYsKvtCymp2YJMjpT9hlV9epBG8rvC8U0HFXjj2UxUg0CSKQmX3WB7Ztk9HxUrleo9Jl6mVuLC1Yale1CcceS7vzniRnpShNwVk$
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20251215/a99f6806/attachment.html>
Re: Consultation: connecting I2C/SPI devices to network Florian Feldbauer via Tech-talk
Prev: Re: Modbus configuration issues for the Shimaden SRS10A series digital controllers Mark Rivers via Tech-talk
Next: Re: Consultation: connecting I2C/SPI devices to network Gabriel Fedel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Consultation: connecting I2C/SPI devices to network Gabriel Fedel via Tech-talk
Next: Re: Consultation: connecting I2C/SPI devices to network Florian Feldbauer via Tech-talk
