Hey Kuldeep,
I did not patch asyn but I needed to patch StreamDevice to use it
with my I2C device support.
Each chip uses a different protocol for the communication, and
since StreamDevice offers raw converters (%r, %R) I thought it was
the easiest to just write a generic AsynPortDriver with an Octet
interface and define the chip specific communication within a
protocol file.
However, there was one issue:
The writeHandler of StreamDevice's AsynInterface tries to flush
any buffered messages before sending by reading 256 bytes until
the driver returns asynTimeout or asynError.
As soon as a valid slave address is set up in the I2C kernel
module, such a read call will always succeed and thus returns
asynSuccess.
This resulted in an endless loop, because StreamDevice kept
reading from the I2C bus.
https://github.com/paulscherrerinstitute/StreamDevice/blob/master/src/AsynDriverInterface.cc#L612C1-L639C6
if (!pasynGpib)
// discard any early input, but forward it to potential
async records
// thus do not use pasynOctet->flush()
// unfortunately we cannot do this with GPIB because
addressing a
// device as talker when it has nothing to say is an
error.
// Also timeout=0 does not help here (would need a
change in asynGPIB),
// thus use flush() for GPIB.
do {
char buffer [256];
size_t received = 0;
int eomReason = 0;
debug("AsynDriverInterface::writeHandler(%s):
reading old input\n",
clientName());
status = pasynOctet->read(pvtOctet, pasynUser,
buffer, sizeof(buffer), &received,
&eomReason);
if (status == asynError || received == 0) break;
if (received)
debug("AsynDriverInterface::writeHandler(%s): "
"flushing %" Z "u bytes: \"%s\"\n",
clientName(), received, StreamBuffer(buffer,
received).expand()());
} while (status == asynSuccess);
else
debug("AsynDriverInterface::writeHandler(%s): flushing
old input\n",
clientName());
pasynOctet->flush(pvtOctet, pasynUser);
As you can see from this code snippet, StreamDevice behaves
differently when used in conjunction with a GPIB interface.
So I simply created a corresponding type for I2C in my module and
patched the above if statement in StreamDevice to be
if (!pasynGpib && !pasynI2C)
The full patch is included in the git repo here:
https://github.com/ffeldbauer/drvAsynI2C/blob/master/streamDevice/stream_drvasyni2c_2.8.20.patch
Except for this there is some initialization for the i2c
interface but that's it.
Therefore the behaviour of StreamDevice with other AsynDrivers
(e.g. SerialPort/IPPort/GPIB/...) stays untouched.
We have IOCs here that use a patched version of StreamDevice with
RS485/RS232 as well as I2C and it works.
Hope that answers your question,
Cheers,
Florian
On 12/17/25 05:26, Kuldeep Joshi wrote:
Hello Florian,
I have superficially seen your code for the I2C to CA/PVA
module.
I have a quick query regarding this,
you have patched the asyn module due to some issue. Can
you please elaborate on this.
If I want to use the asyn module along with Modbus, what
will be the issues faced while using this patched module??
Kuldeep Joshi
Date:
Mon, 15 Dec 2025 11:30:39 +0100
To: [email protected]
Subject: Re: Consultation: connecting I2C/SPI devices to
network
Message-ID:
<[email protected]"
target="_blank" moz-do-not-send="true"
class="moz-txt-link-freetext">[email protected]>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Hey Gabriel,
I typically use a Raspberry Pi to readout devices via I2C.
For this task I wrote a small i2c device support module,
that uses
Stream Device + Asyn (https://urldefense.us/v3/__https://github.com/ffeldbauer/drvAsynI2C__;!!G_uCfscf7eWS!dYsKvtCymp2YJMjpT9hlV9epBG8rvC8U0HFXjj2UxUg0CSKQmX3WB7Ztk9HxUrleo9Jl6mVuLC1Yale1CcceS7vzniRnZn_gqG4$
It does not make the I2C communication directly accessible
on network,
but it makes all the data points accessible via CA/PVA
through an EPICS IOC.
If you really want to have a I2C to Ethernet bridge, I would
most likely
use a RP2040 or ESP32 microcontroller and implement a simple
UDP or TCP
protocol exchanging either ASCII or raw "strings" containing
the data.
HTH,
Florian
On 12/15/25 10:43, Gabriel Fedel via Tech-talk wrote:
> Dear tech-talk,
> Any experience or suggestion of bringing hardware
communicating I2C
> and/or SPI to be accessible on network?
> Maybe even some EPICS integration experience on them ?
> Thanks in advance
Ruhr-Universit?t Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universit?tsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://urldefense.us/v3/__https://paluma.ruhr-uni-bochum.de__;!!G_uCfscf7eWS!dYsKvtCymp2YJMjpT9hlV9epBG8rvC8U0HFXjj2UxUg0CSKQmX3WB7Ztk9HxUrleo9Jl6mVuLC1Yale1CcceS7vzniRnpShNwVk$
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20251215/a99f6806/attachment.html>
Ruhr-Universität Bochum
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
- Re: Consultation: connecting I2C/SPI devices to network Kuldeep Joshi via Tech-talk
Re: Consultation: connecting I2C/SPI devices to network Gabriel Fedel via Tech-talk
EPICS Collaboration Meeting Spring 2026 - CEA IRFU Paris-Saclay GAGET Alexis via Tech-talk
<2025>
2026
Modbus configuration issues for the Shimaden SRS10A series digital controllers LONG FENG via Tech-talk
<2025>
2026
