Hi Feng,
The stream device checksum function names are looked up via
https://github.com/paulscherrerinstitute/StreamDevice/blob/929204cb13f122e2ff3beb64ab86d8bdb6a21d70/src/ChecksumConverter.cc#L640
so you just need to add your calculation function to this (or a separate) file and then reference it from the checksumMap variable
Freddie
On Behalf Of LONG FENG via Tech-talk
Sent: 19 December 2025 08:13
To: [email protected]
Subject: How to implement a custom CRC check function in StreamDevice?
Hi all,
StreamDevice provides some common CRC check methods, such as
%<crc16>. However, sometimes we encounter non-standard CRC checks, like the CRC check of the SQM160, as shown in the figure .
In this case, we need to write a function to implement a custom CRC check and include this custom CRC function in the
.proto file.
How can we implement this process?
- How to implement a custom CRC check function in StreamDevice? LONG FENG via Tech-talk
The problem of slow response of drvAsynIPServer PortConfigure method bombbird02 via Tech-talk
AreaDetector Collaboration Meeting - January 8th Érico Nogueira Rolim via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
