1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: PVXS release 1.5.0 and P4P 4.2.2
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Wed, 7 Jan 2026 19:28:58 -0800
PVXS 1.5.0 and P4P 4.2.2 are now available in the usual places.
These are bug fix releases.  The switch from PVXS 1.4.x to 1.5x is due to an ABI change in libpvxsIoc to avoid a symbol name clash with libqsrv.
I anticipate that these will be the final releases supporting python 2.7 or 3.7.
For these releases, the set of binaries uploaded to pypi.org is reduced to only cpython 3.8 through 3.14 for Linux/amd64, OSX/universal, and Win64.  py2.7 and py3.7 support is still tested, but anyone still using these versions will need to build from source.
download: https ://github.com/epics-base/pvxs/releases
documentation: https ://epics-base.github.io/pvxs
release notes: https ://epics-base.github.io/pvxs/releasenotes.html
Prev: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice Mark Rivers via Tech-talk
Next: Re: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice 高振华 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Device Support for Tektronix MSO oscilloscope Sukhanov, Andrei via Tech-talk
Next: problems with SNL - sevr=minor ca_array_get_callback [...]: Virtual circuit disconnect Dariush Hampai via Tech-talk
