1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: problems with SNL - sevr=minor ca_array_get_callback [...]: Virtual circuit disconnect
From: Dariush Hampai via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 8 Jan 2026 18:19:41 +0100
Dear Community,
Dear Mark and Maurizio,
I'll try to explain my error from which I'm not able to resolve.
I developped a SNL sequencer ablo to make a raster scan with 20 motors (but scalable to how many motors needed) and 20 detectors (same as motors number...). In the link you can find the code (up to now I only use "xena_snscan.stt", as the other ones will be the same) https://urldefense.us/v3/__https://github.com/Teclis77/Scan-Program__;!!G_uCfscf7eWS!aPQyj4WdR7O49u2p_NU4H2lPpTDgz2o1XaIePmAWaJUE8f9HK3CQHpkDwIJWzSP9xdgUviafCfyswv0QGFHqZ1y-Th_61Np0-g$ To test the scan I use procServ in order to start contemporary 3 different IOCs (mm4006 for motors, ortec for detector and the scan). Up to here all is ok.
Using telnet I can monitor the scan IOC and after populate the
1) number of motors;
2) number of detectors;
3) name of motor IOCs involved in the scan;
4) name of detector IOCs involved in the scan;
5) start position for each motor;
6) end position for each motor;
7) step position for each motor
I prepare the the loop using difdferent status_mode value (1 for populate motor variables in stt file, 2 for detector variables, 3 for defing the loop parameters)
When I initialize the scan (status_mode=4), I have a strange error.
Knowing that the variables (for motor_ma, but for the other are the same procedures) are built (in xena_sncscan.stt) as
sprintf(temp_string, "%s:%s", motor[i], setma);
printf("%s\n", temp_string);
pvAssign(motor_ma[i],temp_string);
sprintf(temp_string, "%s:%s", motor[i], reqmoving);
pvAssign(motor_reqmov[i],temp_string);
sprintf(temp_string, "%s:%s", motor[i], moving);
pvAssign(motor_mov[i],temp_string);
sprintf(temp_string, "%s:%s", motor[i], pos);
pvAssign(motor_pos[i],temp_string);
with the output correct form "mm4006_1_1_1:setma", "mm4006_1_1_1:reqmoving", "mm4006_1_1_1:moving" and "mm4006_1_1_1:pos" (these strings work right with caput command in other cmd so they are ok)
and the status_mode=4 is the following
/*=================== Preparing Scan =========================*/
/*=================== status_mode = 4 ========================*/
        state prepare_loop {
                when () {
                        for (i = 0; i < num_mot; i++) {
                                printf("motor to move = %d\n", i);
                                printf("start[%d]= %f\n", i, start[i]);
                                motor_ma[i]=start[i];
                                pvPut(motor_ma[i],SYNC);
                                motor_reqmov[i]=1;
                                pvPut(motor_reqmov[i],SYNC);
                                pvGet(motor_mov[i],SYNC);
                                while(motor_mov[i]<1) {
                                        motor_reqmov[i]=1;
                                pvGet(motor_pos[i], SYNC);
                        flags[0]=1; // Necessary to start the run
                        strcpy(actual_status, "Ready to Start");
                        pvPut(actual_status,SYNC);
                        status_mode=0;
                        pvPut(status_mode);
                } state dummy_loop
in the "telnet" prompt I have the following exit
sevr=minor ca_array_get_callback( typeToCA(type), count, var->chid, pvCaGetHandler, arg): Virtual circuit disconnect
coming from:
using seqChanShow xena_sncscan I obtain
#9 of 263:
  Variable name: "start"
    type = double
    count = 20
  Value = 1000 1500 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
  Assigned to "xena:start"
  Connected
  Monitored
  Not sync'ed
  Status = 0
  Severity = 0
  Message =
  Time stamp = 2026-01-08 17:26:57.769209
Next? (+/- skip count)
and
#43 of 263:
  Variable name: "motor_ma[0]"
    type = double
    count = 1
  Value = 1000
  Assigned to "mm4006_1_1_1:setma"
  Not connected
  Monitored
  Not sync'ed
  Status = -2
  Severity = -1
  Message = disconnected
  Time stamp = <undefined>
what I'm wrong?
awaiting your replies...
Dariush
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room:	+39.06.9403.5248
Lab.:	+39.06.9403.2286
Mob.:	+39.06.9403.8025
Fax.:	+39.06.9403.2597
RE: problems with SNL - sevr=minor ca_array_get_callback [...]: Virtual circuit disconnect Žiga Oven via Tech-talk
Prev: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice Zimoch, Dirk via Tech-talk
Next: RE: problems with SNL - sevr=minor ca_array_get_callback [...]: Virtual circuit disconnect Žiga Oven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: PVXS release 1.5.0 and P4P 4.2.2 Michael Davidsaver via Tech-talk
