I tried and after calling "seqcar 2” before assigning the variables it works for a while… then it stops again…
Program "xena_sncscan"
Variable "name_exp_pv" connected to PV "xena:experiment"
Variable "status_mode" connected to PV "xena:status"
Variable "actual_status" connected to PV "xena:state"
Variable "scan_busy" connected to PV "xena:scan_busy"
Variable "scan_pause" connected to PV "xena:scan_pause"
Variable "scan_restart" connected to PV "xena:scan_restart"
Variable "scan_abort" connected to PV "xena:scan_abort"
Variable "num_mot" connected to PV "xena:num_motor"
Variable "num_det" connected to PV "xena:num_detector"
Variable "start" connected to PV "xena:start"
Variable "end" connected to PV "xena:end"
Variable "step" connected to PV "xena:step"
Variable "total_points" connected to PV "xena:total_points"
Variable "current_point" connected to PV "xena:current_point"
Variable "scan_progress" connected to PV "xena:scan_progress"
Variable "motor" connected to PV "xena:motor"
Variable "mot_command" connected to PV "xena:motor_command"
Variable "detector" connected to PV "xena:detector"
Variable "det_command" connected to PV "xena:detector_command"
Variable "motget" not assigned to PV
Variable "motset" not assigned to PV
Variable "detget" not assigned to PV
Variable "detset" not assigned to PV
Variable "motor_mr[0]" not assigned to PV
Variable "motor_mr[1]" not assigned to PV
Variable "motor_mr[2]" not assigned to PV
Variable "motor_mr[3]" not assigned to PV
Variable "motor_mr[4]" not assigned to PV
Variable "motor_mr[5]" not assigned to PV
Variable "motor_mr[6]" not assigned to PV
Variable "motor_mr[7]" not assigned to PV
Variable "motor_mr[8]" not assigned to PV
Variable "motor_mr[9]" not assigned to PV
Variable "motor_mr[10]" not assigned to PV
Variable "motor_mr[11]" not assigned to PV
Variable "motor_mr[12]" not assigned to PV
Variable "motor_mr[13]" not assigned to PV
Variable "motor_mr[14]" not assigned to PV
Variable "motor_mr[15]" not assigned to PV
Variable "motor_mr[16]" not assigned to PV
Variable "motor_mr[17]" not assigned to PV
Variable "motor_mr[18]" not assigned to PV
Variable "motor_mr[19]" not assigned to PV
Variable "motor_ma[0]" not assigned to PV
Variable "motor_ma[1]" not assigned to PV
Variable "motor_ma[2]" not assigned to PV
Variable "motor_ma[3]" not assigned to PV
Variable "motor_ma[4]" not assigned to PV
Variable "motor_ma[5]" not assigned to PV
Variable "motor_ma[6]" not assigned to PV
Variable "motor_ma[7]" not assigned to PV
Variable "motor_ma[8]" not assigned to PV
Variable "motor_ma[9]" not assigned to PV
Variable "motor_ma[10]" not assigned to PV
Variable "motor_ma[11]" not assigned to PV
Variable "motor_ma[12]" not assigned to PV
Variable "motor_ma[13]" not assigned to PV
Variable "motor_ma[14]" not assigned to PV
Variable "motor_ma[15]" not assigned to PV
Variable "motor_ma[16]" not assigned to PV
Variable "motor_ma[17]" not assigned to PV
Variable "motor_ma[18]" not assigned to PV
Variable "motor_ma[19]" not assigned to PV
Variable "motor_reqmov[0]" not assigned to PV
Variable "motor_reqmov[1]" not assigned to PV
Variable "motor_reqmov[2]" not assigned to PV
Variable "motor_reqmov[3]" not assigned to PV
Variable "motor_reqmov[4]" not assigned to PV
Variable "motor_reqmov[5]" not assigned to PV
Variable "motor_reqmov[6]" not assigned to PV
Variable "motor_reqmov[7]" not assigned to PV
Variable "motor_reqmov[8]" not assigned to PV
Variable "motor_reqmov[9]" not assigned to PV
Variable "motor_reqmov[10]" not assigned to PV
Variable "motor_reqmov[11]" not assigned to PV
Variable "motor_reqmov[12]" not assigned to PV
Variable "motor_reqmov[13]" not assigned to PV
Variable "motor_reqmov[14]" not assigned to PV
Variable "motor_reqmov[15]" not assigned to PV
Variable "motor_reqmov[16]" not assigned to PV
Variable "motor_reqmov[17]" not assigned to PV
Variable "motor_reqmov[18]" not assigned to PV
Variable "motor_reqmov[19]" not assigned to PV
Variable "motor_mov[0]" not assigned to PV
Variable "motor_mov[1]" not assigned to PV
Variable "motor_mov[2]" not assigned to PV
Variable "motor_mov[3]" not assigned to PV
Variable "motor_mov[4]" not assigned to PV
Variable "motor_mov[5]" not assigned to PV
Variable "motor_mov[6]" not assigned to PV
Variable "motor_mov[7]" not assigned to PV
Variable "motor_mov[8]" not assigned to PV
Variable "motor_mov[9]" not assigned to PV
Variable "motor_mov[10]" not assigned to PV
Variable "motor_mov[11]" not assigned to PV
Variable "motor_mov[12]" not assigned to PV
Variable "motor_mov[13]" not assigned to PV
Variable "motor_mov[14]" not assigned to PV
Variable "motor_mov[15]" not assigned to PV
Variable "motor_mov[16]" not assigned to PV
Variable "motor_mov[17]" not assigned to PV
Variable "motor_mov[18]" not assigned to PV
Variable "motor_mov[19]" not assigned to PV
Variable "motor_reqpos[0]" not assigned to PV
Variable "motor_reqpos[1]" not assigned to PV
Variable "motor_reqpos[2]" not assigned to PV
Variable "motor_reqpos[3]" not assigned to PV
Variable "motor_reqpos[4]" not assigned to PV
Variable "motor_reqpos[5]" not assigned to PV
Variable "motor_reqpos[6]" not assigned to PV
Variable "motor_reqpos[7]" not assigned to PV
Variable "motor_reqpos[8]" not assigned to PV
Variable "motor_reqpos[9]" not assigned to PV
Variable "motor_reqpos[10]" not assigned to PV
Variable "motor_reqpos[11]" not assigned to PV
Variable "motor_reqpos[12]" not assigned to PV
Variable "motor_reqpos[13]" not assigned to PV
Variable "motor_reqpos[14]" not assigned to PV
Variable "motor_reqpos[15]" not assigned to PV
Variable "motor_reqpos[16]" not assigned to PV
Variable "motor_reqpos[17]" not assigned to PV
Variable "motor_reqpos[18]" not assigned to PV
Variable "motor_reqpos[19]" not assigned to PV
Variable "motor_pos[0]" not assigned to PV
Variable "motor_pos[1]" not assigned to PV
Variable "motor_pos[2]" not assigned to PV
Variable "motor_pos[3]" not assigned to PV
Variable "motor_pos[4]" not assigned to PV
Variable "motor_pos[5]" not assigned to PV
Variable "motor_pos[6]" not assigned to PV
Variable "motor_pos[7]" not assigned to PV
Variable "motor_pos[8]" not assigned to PV
Variable "motor_pos[9]" not assigned to PV
Variable "motor_pos[10]" not assigned to PV
Variable "motor_pos[11]" not assigned to PV
Variable "motor_pos[12]" not assigned to PV
Variable "motor_pos[13]" not assigned to PV
Variable "motor_pos[14]" not assigned to PV
Variable "motor_pos[15]" not assigned to PV
Variable "motor_pos[16]" not assigned to PV
Variable "motor_pos[17]" not assigned to PV
Variable "motor_pos[18]" not assigned to PV
Variable "motor_pos[19]" not assigned to PV
Variable "detector_reqstart[0]" not assigned to PV
Variable "detector_reqstart[1]" not assigned to PV
Variable "detector_reqstart[2]" not assigned to PV
Variable "detector_reqstart[3]" not assigned to PV
Variable "detector_reqstart[4]" not assigned to PV
Variable "detector_reqstart[5]" not assigned to PV
Variable "detector_reqstart[6]" not assigned to PV
Variable "detector_reqstart[7]" not assigned to PV
Variable "detector_reqstart[8]" not assigned to PV
Variable "detector_reqstart[9]" not assigned to PV
Variable "detector_reqstart[10]" not assigned to PV
Variable "detector_reqstart[11]" not assigned to PV
Variable "detector_reqstart[12]" not assigned to PV
Variable "detector_reqstart[13]" not assigned to PV
Variable "detector_reqstart[14]" not assigned to PV
Variable "detector_reqstart[15]" not assigned to PV
Variable "detector_reqstart[16]" not assigned to PV
Variable "detector_reqstart[17]" not assigned to PV
Variable "detector_reqstart[18]" not assigned to PV
Variable "detector_reqstart[19]" not assigned to PV
Variable "detector_reqready[0]" not assigned to PV
Variable "detector_reqready[1]" not assigned to PV
Variable "detector_reqready[2]" not assigned to PV
Variable "detector_reqready[3]" not assigned to PV
Variable "detector_reqready[4]" not assigned to PV
Variable "detector_reqready[5]" not assigned to PV
Variable "detector_reqready[6]" not assigned to PV
Variable "detector_reqready[7]" not assigned to PV
Variable "detector_reqready[8]" not assigned to PV
Variable "detector_reqready[9]" not assigned to PV
Variable "detector_reqready[10]" not assigned to PV
Variable "detector_reqready[11]" not assigned to PV
Variable "detector_reqready[12]" not assigned to PV
Variable "detector_reqready[13]" not assigned to PV
Variable "detector_reqready[14]" not assigned to PV
Variable "detector_reqready[15]" not assigned to PV
Variable "detector_reqready[16]" not assigned to PV
Variable "detector_reqready[17]" not assigned to PV
Variable "detector_reqready[18]" not assigned to PV
Variable "detector_reqready[19]" not assigned to PV
Variable "detector_ready[0]" not assigned to PV
Variable "detector_ready[1]" not assigned to PV
Variable "detector_ready[2]" not assigned to PV
Variable "detector_ready[3]" not assigned to PV
Variable "detector_ready[4]" not assigned to PV
Variable "detector_ready[5]" not assigned to PV
Variable "detector_ready[6]" not assigned to PV
Variable "detector_ready[7]" not assigned to PV
Variable "detector_ready[8]" not assigned to PV
Variable "detector_ready[9]" not assigned to PV
Variable "detector_ready[10]" not assigned to PV
Variable "detector_ready[11]" not assigned to PV
Variable "detector_ready[12]" not assigned to PV
Variable "detector_ready[13]" not assigned to PV
Variable "detector_ready[14]" not assigned to PV
Variable "detector_ready[15]" not assigned to PV
Variable "detector_ready[16]" not assigned to PV
Variable "detector_ready[17]" not assigned to PV
Variable "detector_ready[18]" not assigned to PV
Variable "detector_ready[19]" not assigned to PV
Variable "detector_reqdata[0]" not assigned to PV
Variable "detector_reqdata[1]" not assigned to PV
Variable "detector_reqdata[2]" not assigned to PV
Variable "detector_reqdata[3]" not assigned to PV
Variable "detector_reqdata[4]" not assigned to PV
Variable "detector_reqdata[5]" not assigned to PV
Variable "detector_reqdata[6]" not assigned to PV
Variable "detector_reqdata[7]" not assigned to PV
Variable "detector_reqdata[8]" not assigned to PV
Variable "detector_reqdata[9]" not assigned to PV
Variable "detector_reqdata[10]" not assigned to PV
Variable "detector_reqdata[11]" not assigned to PV
Variable "detector_reqdata[12]" not assigned to PV
Variable "detector_reqdata[13]" not assigned to PV
Variable "detector_reqdata[14]" not assigned to PV
Variable "detector_reqdata[15]" not assigned to PV
Variable "detector_reqdata[16]" not assigned to PV
Variable "detector_reqdata[17]" not assigned to PV
Variable "detector_reqdata[18]" not assigned to PV
Variable "detector_reqdata[19]" not assigned to PV
Variable "detector_data[0]" not assigned to PV
Variable "detector_data[1]" not assigned to PV
Variable "detector_data[2]" not assigned to PV
Variable "detector_data[3]" not assigned to PV
Variable "detector_data[4]" not assigned to PV
Variable "detector_data[5]" not assigned to PV
Variable "detector_data[6]" not assigned to PV
Variable "detector_data[7]" not assigned to PV
Variable "detector_data[8]" not assigned to PV
Variable "detector_data[9]" not assigned to PV
Variable "detector_data[10]" not assigned to PV
Variable "detector_data[11]" not assigned to PV
Variable "detector_data[12]" not assigned to PV
Variable "detector_data[13]" not assigned to PV
Variable "detector_data[14]" not assigned to PV
Variable "detector_data[15]" not assigned to PV
Variable "detector_data[16]" not assigned to PV
Variable "detector_data[17]" not assigned to PV
Variable "detector_data[18]" not assigned to PV
Variable "detector_data[19]" not assigned to PV
Variable "detector_type[0]" not assigned to PV
Variable "detector_type[1]" not assigned to PV
Variable "detector_type[2]" not assigned to PV
Variable "detector_type[3]" not assigned to PV
Variable "detector_type[4]" not assigned to PV
Variable "detector_type[5]" not assigned to PV
Variable "detector_type[6]" not assigned to PV
Variable "detector_type[7]" not assigned to PV
Variable "detector_type[8]" not assigned to PV
Variable "detector_type[9]" not assigned to PV
Variable "detector_type[10]" not assigned to PV
Variable "detector_type[11]" not assigned to PV
Variable "detector_type[12]" not assigned to PV
Variable "detector_type[13]" not assigned to PV
Variable "detector_type[14]" not assigned to PV
Variable "detector_type[15]" not assigned to PV
Variable "detector_type[16]" not assigned to PV
Variable "detector_type[17]" not assigned to PV
Variable "detector_type[18]" not assigned to PV
Variable "detector_type[19]" not assigned to PV
### AFTER:
Variable "motor_mr[0]" connected to PV "mm4006_1_1_1:setmr"
Variable "motor_mr[1]" connected to PV "mm4006_1_1_2:setmr"
Variable "motor_ma[0]" connected to PV "mm4006_1_1_1:setma"
Variable "motor_ma[1]" connected to PV "mm4006_1_1_2:setma"
Variable "motor_reqmov[0]" connected to PV "mm4006_1_1_1:reqmoving"
Variable "motor_reqmov[1]" connected to PV "mm4006_1_1_2:reqmoving"
Variable "motor_mov[0]" connected to PV "mm4006_1_1_1:moving"
Variable "motor_mov[1]" connected to PV "mm4006_1_1_2:moving"
Variable "motor_reqpos[0]" connected to PV "mm4006_1_1_1:reqpos"
Variable "motor_reqpos[1]" connected to PV "mm4006_1_1_2:reqpos"
Variable "motor_pos[0]" connected to PV "mm4006_1_1_1:pos"
Variable "motor_pos[1]" connected to PV "mm4006_1_1_2:pos"
Variable "detector_reqstart[0]" not connected to PV "ortec_1_1_1:reqstart"
Variable "detector_reqready[0]" not connected to PV "ortec_1_1_1:reqready"
Variable "detector_ready[0]" not connected to PV "ortec_1_1_1:ready"
Variable "detector_reqdata[0]" not connected to PV "ortec_1_1_1:reqdata"
Variable "detector_data[0]" not connected to PV "ortec_1_1_1:data"
Variable "detector_type[0]" not connected to PV "ortec_1_1_1:type"
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room: +39.06.9403.5248
Lab.: +39.06.9403.2286
Mob.: +39.06.9403.8025
Fax.: +39.06.9403.2597
Il giorno 8 gen 2026, alle ore 19:19, Žiga Oven <ziga.oven at cosylab.com> ha scritto:
Hi Dariush,
I would check is if the IOC that runs the sequencer has access to the PVs in the other (I assume motor) IOCs.
If you issue the command "seqcar 2" on the IOC that runs the sequencer, this should report the status of the sequencer's access to the PVs.
Sequencer does provide you option to force all PVs to be connected before it starts the program execution, by using the "+c" option during the compile time
https://epics-modules.github.io/sequencer/Compiling.html?highlight=options#compiler-optionsBest regards,
Žiga
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Dariush Hampai
via Tech-talk
Sent: Thursday, January 8, 2026 10:20
To: tech-talk at aps.anl.gov
Subject: problems with SNL - sevr=minor ca_array_get_callback [...]: Virtual
circuit disconnect
Caution: This email originated from outside of Cosylab.
Dear Community,
Dear Mark and Maurizio,
I'll try to explain my error from which I'm not able to resolve.
I developped a SNL sequencer ablo to make a raster scan with 20 motors (but
scalable to how many motors needed) and 20 detectors (same as motors
number...).
In the link you can find the code (up to now I only use "xena_snscan.stt", as the
other ones will be the same)
https://urldefense.us/v3/__https://github.com/Teclis77/Scan-
Program__;!!G_uCfscf7eWS!aPQyj4WdR7O49u2p_NU4H2lPpTDgz2o1XaIePmA
WaJUE8f9HK3CQHpkDwIJWzSP9xdgUviafCfyswv0QGFHqZ1y-Th_61Np0-g$
To test the scan I use procServ in order to start contemporary 3 different IOCs
(mm4006 for motors, ortec for detector and the scan). Up to here all is ok.
Using telnet I can monitor the scan IOC and after populate the
1) number of motors;
2) number of detectors;
3) name of motor IOCs involved in the scan;
4) name of detector IOCs involved in the scan;
5) start position for each motor;
6) end position for each motor;
7) step position for each motor
I prepare the the loop using difdferent status_mode value (1 for populate
motor variables in stt file, 2 for detector variables, 3 for defing the loop
parameters) When I initialize the scan (status_mode=4), I have a strange error.
Knowing that the variables (for motor_ma, but for the other are the same
procedures) are built (in xena_sncscan.stt) as
sprintf(temp_string, "%s:%s", motor[i], setma); printf("%s\n", temp_string);
pvAssign(motor_ma[i],temp_string);
sprintf(temp_string, "%s:%s", motor[i], reqmoving); printf("%s\n",
temp_string); pvAssign(motor_reqmov[i],temp_string);
sprintf(temp_string, "%s:%s", motor[i], moving); printf("%s\n", temp_string);
pvAssign(motor_mov[i],temp_string);
sprintf(temp_string, "%s:%s", motor[i], pos); printf("%s\n", temp_string);
pvAssign(motor_pos[i],temp_string);
with the output correct form "mm4006_1_1_1:setma",
"mm4006_1_1_1:reqmoving", "mm4006_1_1_1:moving" and
"mm4006_1_1_1:pos"
(these strings work right with caput command in other cmd so they are ok)
and the status_mode=4 is the following
/*=================== Preparing Scan =========================*/
/*=================== status_mode = 4 ========================*/
state prepare_loop {
when () {
for (i = 0; i < num_mot; i++) {
printf("motor to move = %d\n", i);
printf("start[%d]= %f\n", i, start[i]);
motor_ma[i]=start[i];
pvPut(motor_ma[i],SYNC);
motor_reqmov[i]=1;
pvPut(motor_reqmov[i],SYNC);
pvGet(motor_mov[i],SYNC);
while(motor_mov[i]<1) {
motor_reqmov[i]=1; pvPut(motor_reqmov[i],SYNC);
pvGet(motor_pos[i], SYNC);
flags[0]=1; // Necessary to start the run
strcpy(actual_status, "Ready to Start");
pvPut(actual_status,SYNC);
status_mode=0;
pvPut(status_mode);
} state dummy_loop
in the "telnet" prompt I have the following exit sevr=minor
ca_array_get_callback( typeToCA(type), count, var->chid, pvCaGetHandler, arg):
Virtual circuit disconnect
coming from:
using seqChanShow xena_sncscan I obtain
#9 of 263:
Variable name: "start"
type = double
count = 20
Value = 1000 1500 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Assigned to "xena:start"
Connected
Monitored
Not sync'ed
Status = 0
Severity = 0
Message =
Time stamp = 2026-01-08 17:26:57.769209 Next? (+/- skip count)
and
#43 of 263:
Variable name: "motor_ma[0]"
type = double
count = 1
Value = 1000
Assigned to "mm4006_1_1_1:setma"
Not connected
Monitored
Not sync'ed
Status = -2
Severity = -1
Message = disconnected
Time stamp = <undefined>
what I'm wrong?
awaiting your replies...
Dariush
INFN - LNF
X-Lab Frascati
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
