1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Configuration of the RGA200 communication baud rate
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, LONG FENG <feng98716 at gmail.com>
Date: Mon, 12 Jan 2026 14:31:10 +0000
Hi Feng,
I just tried to set the serial port of /dev/ttyUSB0 on my Linux system to 28800 with the stty command.  It did not work, consistent with what you observed.
 ChatGPT says that Moxa terminal servers do support non-standard baud rates.  I tested a Moxa NPort terminal server.  Although it does not support 28,800 as a preset choice in the menu, it does support "Other".  I selected "Other" and entered 28800, and it accepted it.  So this may be a solution for you.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of LONG FENG via Tech-talk <tech-talk at aps.anl.gov>
Sent: Sunday, January 11, 2026 11:29 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Configuration of the RGA200 communication baud rate
Hi all,
We encountered an issue while configuring the communication baud rate for the RGA200. As you know, the RGA uses a baud rate of 28,800, but EPICS does not seem to allow setting this baud rate. As a result, it reports the following error:
drvAsynSerialPortConfigure ("RGA200", "/dev/ttyUSB0")
asynSetOption("RGA200", 0, "baud", "28800")
setOption failed Unsupported data rate (28800 baud)
How should this issue be resolved?
Feng
Configuration of the RGA200 communication baud rate LONG FENG via Tech-talk
Prev: Alarm Server to SMS? Paul Sichta via Tech-talk
Next: Re: Configuration of the RGA200 communication baud rate Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Configuration of the RGA200 communication baud rate Hu, Yong via Tech-talk
