1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Configuration of the RGA200 communication baud rate
From: LONG FENG via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 12 Jan 2026 13:29:57 +0800
Hi all,
We encountered an issue while configuring the communication baud rate for the RGA200. As you know, the RGA uses a baud rate of 28,800, but EPICS does not seem to allow setting this baud rate. As a result, it reports the following error:
drvAsynSerialPortConfigure ("RGA200", "/dev/ttyUSB0")
asynSetOption("RGA200", 0, "baud", "28800")
setOption failed Unsupported data rate (28800 baud)
How should this issue be resolved?
Feng
Re: Configuration of the RGA200 communication baud rate Hu, Yong via Tech-talk
Re: Configuration of the RGA200 communication baud rate Mark Rivers via Tech-talk
Re: Configuration of the RGA200 communication baud rate Eric Norum via Tech-talk
Prev: Problems with clang under MacOS Torsten Bögershausen via Tech-talk
Next: Re: Configuration of the RGA200 communication baud rate Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Problems with clang under MacOS Torsten Bögershausen via Tech-talk
