I did try a patch instead, please see
https://urldefense.us/v3/__https://github.com/epics-modules/asyn/pull/226__;!!G_uCfscf7eWS!e5LsTRb4GyB0wj1lNmm5cY6InN7fv2H7wAFKAA8XDtaLKk7_jCZ5wtk13GIDlruzjK0dI5pAYdq6F2Pzhxc$
> On 2026-01-12 21:08, Michael Davidsaver wrote:
> Could you open an issue for asyn?
> It looks like some cleverness in asyn now conflicts with some cleverness
> in clang.
> On 1/10/26 7:02 AM, Torsten Bögershausen via Tech-talk wrote:>> Hej
Experts,
after problems with C++ code I needed to re-install the
xcode command line tools here.
However, trying to compile a motor driver didn't work very well:
../smarActMCS2MotorDriver.cpp:151:10: error: integer value 10 is
outside the valid range of
values [0, 7] for the enumeration type 'asynStatus' [-Wenum-
constexpr-conversion]
151 | case asynParamUndefined:
c++ --version
Apple clang version 17.0.0 (clang-1700.6.3.2)
Are there any better suggestions ?
- Problems with clang under MacOS Torsten Bögershausen via Tech-talk
- Re: Problems with clang under MacOS Michael Davidsaver via Tech-talk
Re: Configuration of the RGA200 communication baud rate Dmitry Yu. Bolkhovityanov via Tech-talk
Re: Re: Archiver Appliance stuck on initial sampling Sky Brewer via Tech-talk
2025
<2026>
Configuration of the RGA200 communication baud rate LONG FENG via Tech-talk
2025
<2026>
