Hey Ralph,
Yes, the archiver has a rate limit for searching for the meta info of a thousand by default:
And then the meta channels, I just reckon they are all the same type of PV with 7 meta channels each. The meta channel list depends on your policy file, but I think this is probably all the alarm ones, HIHI, HI, etc.
There is a separate limit for the meta channels search:
There are no meta channels if using PVA (which means lots of functionality PVA to CA is different for the meta data).
Hope that helps
Sky
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
