1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: Configuration of the RGA200 communication baud rate
From: Charter via Tech-talk <tech-talk at aps.anl.gov>
To: Eric Norum <eric at norum.ca>
Cc: tech-talk at aps.anl.gov
Date: Thu, 15 Jan 2026 21:10:24 -0500
Also, see https://www.downtowndougbrown.com/2013/11/linux-custom-serial-baud-rates/
John
On Jan 13, 2026, at 3:52 PM, Eric Norum via Tech-talk <tech-talk at aps.anl.gov> wrote:
I'm inclined to agree.  Adding a bunch of kernel/platform-specific ifdef’s to drvAsynSerialPort.c isn’t very appealing.
My first thought at a workaround was to suggest invoking an iocsh ’system’  command to run a python program to set the line rate after all calls to asynSetOption.
This *might* work as long as read timeouts never change — changing a read timeout results in a call to tcsetattr() which would overwrite the speed set by the python program.  Pretty fragile, though.
Or perhaps there’s a way to enable 28.8kbaud in the kernel and thus in termios.h?  The ASYN driver will allow this speed if it’s present in termios.h.
On Jan 13, 2026, at 12:09 PM, J. Lewis Muir <jlmuir at imca-cat.org> wrote:
On 01/13, Érico Nogueira Rolim via Tech-talk wrote:
Just something to note if anyone wishes to use that post as reference (and the recent glibc support isn't enough). It mentions an issue with including kernel headers:
I ran into some #include hell with asm/termios.h, especially if I already had the normal termios.h included elsewhere, so you might have to copy relevant struct definitions into your own code if you can’t get it to work (I know, nasty!). The other thing to keep in mind is that the definition of NCCS might be different between your libc and kernel, so you need to make sure you’re using the kernel’s definition of NCCS. I believe asm/termbits.h has the correct NCCS and structures defined.
The kernel docs explicitly recommend copying struct definitions into userspace code that uses syscalls/ioctls directly. That way you can be sure of what version is in use, and you can name structs appropriately in order to avoid any conflicts. This can get messy if the kernel definitions vary by architecture, and then violating that recommendation becomes more reasonable, so I hope that's not the case.
?? Sounds like a terrible idea to me.  If kernel-related structs are
needed from userspace, the OS should provide appropriate header files
defining those that are either shared by userspace and kernelspace thus
ensuring that they're consistent, or, if separate sets for userspace and
kernelspace, are at least guaranteed to be consistent with each other.
Lewis
Eric Norum
eric at norum.ca
Re: Configuration of the RGA200 communication baud rate Eric Norum via Tech-talk
Prev: Re: Configuration of the RGA200 communication baud rate Charter via Tech-talk
Next: Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS lvhh--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Next: Re: Configuration of the RGA200 communication baud rate Eric Norum via Tech-talk
