1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS
From: lvhh--- via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 16 Jan 2026 17:39:44 +0800
Dear all,
We have a custom device generating 500k-point waveform data (float32/float64 arrays) and need to convert it to EPICS PVData for system integration. We seek guidance on two key points:
1.What communication protocol should the custom device support? Given the large waveform size, we prioritize high throughput, low latency, and structured data (to bundle waveform + metadata like timestamps/units). We wonder which standard industrial protocols are suitable? (e.g. VISA, GigE)
2. Which EPICS modules/tools simplify communication?
The data does not require real-time monitoring. Our local device has a cache, and data can be retrieved from the cache to be stored as EPICS PVs.
Any  documentation references are greatly appreciated!
Best regards,
Huihui
lvhh at sari.ac.cn
Re: Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS Érico Nogueira Rolim via Tech-talk
Re: Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS Sukhanov, Andrei via Tech-talk
Prev: Re: Configuration of the RGA200 communication baud rate Charter via Tech-talk
Next: Bacnet/IP to Modbus TCP Gateway Hardware Recommendations William Jamieson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: RE: Error message of StreamDevice while making it. Xin, Susheng via Tech-talk
Next: Re: Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS Érico Nogueira Rolim via Tech-talk
