Heinz,
Thank you for the recommendation. We are considering using the MOXA 5217 gateway to set the BACnet values to "read only" before passing them onto EPICS as MODBUS records. This will be our method to prevent accidental write operations from EPICS, which are undesirable in our application.
William Jamieson PPPL I&C Engineer
- Bacnet/IP to Modbus TCP Gateway Hardware Recommendations William Jamieson via Tech-talk
- Re: Bacnet/IP to Modbus TCP Gateway Hardware Recommendations Heinz Junkes (FHI) via Tech-talk
Re: Configuration of the RGA200 communication baud rate Eric Norum via Tech-talk
IOCStats 4.0.0 Released Simon Rose via Tech-talk
2025
<2026>
New oac-tree release v1.3 Van Herck Walter via Tech-talk
2025
<2026>
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
