1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: epicsThreadOpts undeclared identifier windows build error
From: "Peterson, Kevin M. via Tech-talk" <tech-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 23 Jan 2026 21:01:18 +0000
Andrew,
Thanks.  Switching from base 3.15 to 7.0 solved the problem.
Kevin
Sent: Friday, January 23, 2026 2:16 PM
To: Peterson, Kevin M.; EPICS Tech Talk
Hi Kevin,
epicsThreadCreateOpt() was added in EPICS 7.0.3.1, it wasn’t present in EPICS 3.15. See https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fepics.anl.gov*2Fbase*2FR7-0*2F3-docs*2FRELEASE_NOTES.html&data=05*7C02*7Ctech-talk*40aps.anl.gov*7Cfa4f15e9ea0f4bb7a77408de5ac28dbc*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639047988800850298*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=2LGVtB37dcjeurWn8dl2HFd1rc16LjU0ehst8fwBfMI*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!ao_ZZm8XxM7FXIodvygUaL4DMZFun2ZobxDTo-R7hTJH_dV7MydNa3_iEZHtMp9xPyJDDPF5m3eeMX-0J99qW1c$ <https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fepics.anl.gov*2Fbase*2FR7-0*2F3-docs*2FRELEASE_NOTES.html&data=05*7C02*7Ctech-talk*40aps.anl.gov*7Cfa4f15e9ea0f4bb7a77408de5ac28dbc*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639047988801105487*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=lnEPd7E4QSZanBZKI*2BwiNnDh3AFw90di18ldlh8L*2FIc*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!ao_ZZm8XxM7FXIodvygUaL4DMZFun2ZobxDTo-R7hTJH_dV7MydNa3_iEZHtMp9xPyJDDPF5m3eeMX-0i-3TWgM$ > for the description. You’ll have to disable CI builds of that module against 3.15.
- Andrew
Complexity comes for free, Simplicity you have to work for.
epicsThreadOpts undeclared identifier windows build error Peterson, Kevin M. via Tech-talk
Re: epicsThreadOpts undeclared identifier windows build error Johnson, Andrew N. via Tech-talk
Prev: Re: [Ext]Re: Modbus linked read/write question Jesse Hopkins via Tech-talk
Next: Re: [Ext]Re: Modbus linked read/write question Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: epicsThreadOpts undeclared identifier windows build error Johnson, Andrew N. via Tech-talk
Next: Support for Gamma Vacuum MPCq ion pump controller over Ethernet Mark Rivers via Tech-talk
