1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: Support for Gamma Vacuum MPCq ion pump controller over Ethernet
From: Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov>
To: 'Mark Rivers' <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sun, 25 Jan 2026 06:28:31 +0000
Hi Mark
We are controlling the QPC model over Ethernet with Stream device. A quick look at MPC user manual shows a very similar Ethernet interface to the QPC. I attached the protocol file, a sample database and a working POC of the Modbus interface. However, from our experience I have some comments:
  • We have been facing an issue with the Ethernet interface where the device does not reply with the appropriate response, for example you request pressure and it returns voltage. Assuming the latest firmware is installed, we used to reboot the IOC to fix it, but if you include asynRecord.db and disconnect the asyn port it will connect again and will work. My initial guess for the root cause is requesting multiple commands at the same time over time, that’s why I made the database processing sequential using a chain of FLNKs, this reduced the issue very much.
  • Though not test thoroughly, I think the Modbus interface is a bit more stable and faster than the ethernet, I tested both on the same controller in the same IOC, I was able to see updates on the Modbus port a bit faster than the Ethernet.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: Saturday, January 24, 2026 1:22 AM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: Support for Gamma Vacuum MPCq ion pump controller over Ethernet
Folks,
I have been using this old C device support to talk to Gamma Vacuum MPC ion pump controllers.
This only talks via RS-232, but many of their newer modules support Ethernet.  The Ethernet message format is somewhat different.  Has anyone written StreamDevice support for the Ethernet protocol?
Thanks
Attachment: gamma-qpc.proto
Description: gamma-qpc.proto
Attachment: gamma-ion-pump.template
Description: gamma-ion-pump.template
Attachment: qpc-modbus.db
Description: qpc-modbus.db
RE: Support for Gamma Vacuum MPCq ion pump controller over Ethernet Abdalla Ahmad via Tech-talk
Re: Support for Gamma Vacuum MPCq ion pump controller over Ethernet LiangChih Chiang via Tech-talk
Support for Gamma Vacuum MPCq ion pump controller over Ethernet Mark Rivers via Tech-talk
Prev: Re: [Ext]Re: Modbus linked read/write question Jesse Hopkins via Tech-talk
Next: RE: Support for Gamma Vacuum MPCq ion pump controller over Ethernet Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Support for Gamma Vacuum MPCq ion pump controller over Ethernet Mark Rivers via Tech-talk
