1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Deployment of the Archiver Appliance
From: LONG FENG via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Sun, 25 Jan 2026 16:48:20 +0800
Hi all,
When I use the install_scripts/single_machine_install.sh script to install the Archiver Appliance, it always reports an error. The error message is as follows:
*** All done ***
Now you can issue "make"
(cd native; make  all)
make[1]: Entering directory '/ics/tools/archiver/tomcat/apache-tomcat-9.0.100/bin/commons-daemon-1.4.1-native-src/unix/native'
gcc   jsvc-unix.o libservice.a -ldl -lpthread -o ../jsvc
make[1]: Leaving directory '/ics/tools/archiver/tomcat/apache-tomcat-9.0.100/bin/commons-daemon-1.4.1-native-src/unix/native'
/ics/tools/archiver/install_scripts
Where's the mysql client jar? - this is named something like mysql-connector-java-5.1.21-bin.jar.
Done copying the mysql client library to /ics/tools/archiver/tomcat/apache-tomcat-9.0.100/lib
I see you have not defined the ARCHAPPL_APPLIANCES environment variable. If we proceed, I'll automatically generate one in /ics/tools/archiver/tomcat. Should we proceed?
Calling ./deployMultipleTomcats.py /ics/tools/archiver/tomcat
Using
tomcat installation at /ics/tools/archiver/tomcat/apache-tomcat-9.0.100
to generate deployments for appliance appliance0
using configuration info from /ics/tools/archiver/tomcat/appliances.xml
into folder /ics/tools/archiver/tomcat
The start/stop port is the standard Tomcat start/stop port. Changing it to something else random - 16000
The stop/start ports for the new instance will being at  16001
Removing  /ics/tools/archiver/tomcat/mgmt
Generating tomcat folder for  mgmt  in location /ics/tools/archiver/tomcat/mgmt
Removing  /ics/tools/archiver/tomcat/engine
Generating tomcat folder for  engine  in location /ics/tools/archiver/tomcat/engine
Removing  /ics/tools/archiver/tomcat/etl
Generating tomcat folder for  etl  in location /ics/tools/archiver/tomcat/etl
Removing  /ics/tools/archiver/tomcat/retrieval
Generating tomcat folder for  retrieval  in location /ics/tools/archiver/tomcat/retrieval
Please enter a MySQL Connection string to an existing database like so
Setting MYSQL_CONNECTION_STRING to --user=archappl --password=archappl --database=archappl
information_schema
I do not see the PVTypeInfo table in --user=archappl --password=archappl --database=archappl? Should we go ahead and create the tables? This step will delete any old data that you have.
Creating tables in --user=archappl --password=archappl --database=archappl
./single_machine_install.sh: line 247: ./archappl_mysql.sql: No such file or directory
Cannot create the MySQL tables. Do you have the right permissions?
What could be the cause of this issue? I have checked the permissions of the archappl database, and they seem fine. I have successfully installed it this way before, but recently, when I try to install it on a new computer, this problem keeps occurring.
Feng
Prev: RE: Support for Gamma Vacuum MPCq ion pump controller over Ethernet Abdalla Ahmad via Tech-talk
Next: Re: Support for Gamma Vacuum MPCq ion pump controller over Ethernet LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: [EXTERNAL] Support for Gamma Vacuum MPCq ion pump controller over Ethernet Webb, Brad via Tech-talk
Next: Investigating Archiver Appliance lost events Abdalla Ahmad via Tech-talk
