1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: OmsAsyn Maxnet Homing
From: "Peterson, Kevin M. via Tech-talk" <tech-talk at aps.anl.gov>
To: "Blomley, Edmund (IBPT)" <edmund.blomley at kit.edu>, EPICS Tech Talk <tech-talk at aps.anl.gov>, "Pearson, Matthew" <pearsonmr at ornl.gov>
Date: Wed, 28 Jan 2026 19:58:56 +0000
The MAXnet controller is a bit of an outlier.  According to the manual I have for it (which was downloaded in 2010) it will *only* home to a dedicated home switch.
I've worked around this problem for a MAXv axis with an encoder by setting HI0 (use only the home input to determine the home position) and then wiring the index line of the encoder into the home input of the MAXv.  For axes without encoders, the other solutions involving the motor record's SET functionality are likely the only options.
Kevin
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Pearson, Matthew via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, January 28, 2026 9:42 AM
To: Blomley, Edmund (IBPT); EPICS Tech Talk
Subject: RE: OmsAsyn Maxnet Homing
That’s fairly common I think. Most controllers won’t support homing to a limit switch, probably because it confuses the function of the switch and the home position would change depending on how fast you move onto the switch.
OmsAsyn Maxnet Homing Blomley, Edmund (IBPT) via Tech-talk
RE: OmsAsyn Maxnet Homing Pearson, Matthew via Tech-talk
Prev: RE: OmsAsyn Maxnet Homing Pearson, Matthew via Tech-talk
Next: Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Next: MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
