1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: MAXnet Alarm State Under High Motor Command Load
From: Jiajun Tian via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 28 Jan 2026 16:32:24 +0000
Hi All,
We are using an OMS MAXnet motor controller via an EPICS IOC, with motion driven by Bluesky plans (Ophyd). Under a high rate of consecutive motor move commands, the motor PVs enter an EPICS alarm state after several moves. When this happens, Ophyd reports a failed MoveStatus, and the Bluesky RunEngine aborts.
The MAXnet is primarily connected via Ethernet. We have also observed similar behavior when using a serial connection, where the issue occurs more frequently.
Has anyone experienced similar MAXnet issues with EPICS, or can advise on relevant settings or configuration considerations?
Related error observed in Bluesky/Ophyd:
ERROR:ophyd.objects: Motion failed: sx is in an alarm state status=AlarmStatus.STATE severity=AlarmSeverity.MAJOR
Thanks in advance,
Jiajun
Jiajun Tian, Ph.D.
Postdoctoral Researcher
NSF’s ChemMatCARS, Pritzker School of Molecular Engineering
University of Chicago
9700 S Cass Ave Bldg 434D
Lemont, IL-60439
United States
Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
Prev: RE: OmsAsyn Maxnet Homing Pearson, Matthew via Tech-talk
Next: Re: pvlist does not find all servers in network Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: OmsAsyn Maxnet Homing Peterson, Kevin M. via Tech-talk
Next: Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
