1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: pvlist does not find all servers in network
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de>
Cc: tech-talk at aps.anl.gov
Date: Wed, 28 Jan 2026 08:32:37 -0800
On 1/28/26 7:24 AM, Florian Feldbauer via Tech-talk wrote:
Ok found the issue.
On the MPOD crate controller, nftable is used as firewall, not iptables....
"iptables" has been a compatibility layer on top of nftables for some years now.  As you have found, "iptables" output will only show rules added through this compatibility layer.  However, "nft" will show all rules, so "nft list ruleset" has become my usual starting point for investigation.
The nftables config was:
  chain output {
    type filter hook output priority 0; policy drop;
followed by a list of a few ports/services on UDP and TCP that were allowed.
From the debug output below (e.g. " 2026-01-28T10:33:24.334 Sending 49 bytes 0.0.0.0:38188 -> 192.168.10.1:53857.")
I guess neither the source nor the destination port of the reply are fixed?
Correct.
Which means, I basically have to change the rules to just accept all outbound UDP traffic
Since this is an outbound rule, the UID/GID of the sending process is available.
 (which I do not really see an issue with....it's in a local subnet anyway).
I agree.  Restrictions on outbound traffic are much less common.
...I know about `netstat -p` und normally use `-tulpn`, but:
root@iseg-iCS2-5230317:~# netstat -tulpn
netstat: invalid option -- 'p'
BusyBox v1.24.1 (2025-05-16 07:17:53 UTC) multi-call binary.
Usage: netstat [-ral] [-tuwx] [-en]
Ah, decade old busybox...  Newer versions support "-p".
pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Re: pvlist does not find all servers in network Michael Davidsaver via Tech-talk
Re: pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Prev: MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Next: AW: OmsAsyn Maxnet Homing Blomley, Edmund (IBPT) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: pvlist does not find all servers in network Florian Feldbauer via Tech-talk
Next: OmsAsyn Maxnet Homing Blomley, Edmund (IBPT) via Tech-talk
