Ok found the issue.
On the MPOD crate controller, nftable is used as firewall, not
iptables....
The nftables config was:
chain output {
type filter hook output priority 0; policy drop;
followed by a list of a few ports/services on UDP and TCP that
were allowed.
From the debug output below (e.g. " 2026-01-28T10:33:24.334
Sending 49 bytes 0.0.0.0:38188 -> 192.168.10.1:53857.")
I guess neither the source nor the destination port of the reply
are fixed?
Which means, I basically have to change the rules to just accept
all outbound UDP traffic (which I do not really see an issue
with....it's in a local subnet anyway).
Cheers,
Florian
On 1/28/26 12:03, Florian Feldbauer via
Tech-talk wrote:
Hey Andrew and Michael,
to answer the obvious questions:
- Output from `uname -a`:
root@iseg-iCS2-5230317:~# uname -a
Linux iseg-iCS2-5230317 4.9.220-2.8.8+g93458a0ecf099 #1 SMP
Fri May 16 07:15:45 UTC 2025 armv7l GNU/Linux
- Broadcast address is 192.168.10.255 on all devices in this
network.
- On the MPOD is only one IOC running.
- On the MPOD EPICS base 7.0.4.1 is running,
- On my PC base 7.0.9 is installed.
In both cases the corresponding tag was recursively checked out
from the git repository and build with the all submodules.
I know about `netstat -p` und normally use `-tulpn`, but:
root@iseg-iCS2-5230317:~# netstat -tulpn
netstat: invalid option -- 'p'
BusyBox v1.24.1 (2025-05-16 07:17:53 UTC) multi-call binary.
Usage: netstat [-ral] [-tuwx] [-en]
Using $EPICS_PVA_DEBUG=3 was a great tip! I thought receiving
the UDP broadcast would be the issue but obviously sending a
reply is:
2026-01-28T10:33:23.690 UDP Client Rx (37)
192.168.10.255:5076 <- 192.168.10.1:53857
2026-01-28T10:33:23.690 Message [0xUDP Server Rx (37)
192.168.10.255:5076 <- 192.168.10.1:538573, v0x2] received
from 192.168.10.1:53857 on 192.168.10.255:5076 :
Message [0x3, v0x2] received from 192.168.10.1:53857 on Search
192.168.10.255:5076 : Search request0x00
0x0000000000 0000000081000000 000000000 81000000 00000000 000
000000000000 .... .... 00 ..... ......
0x10 00. .00ffff 00000000... 61d20000 . 00 ... .. ....
.... a..... .
0x10 0000ffff 00000000 61d20000 00 .... .... a... .
2026-01-28T10:33:23.754 Sending 49 bytes 0.0.0.0:38188 ->
192.168.10.1:53857.
2026-01-28T10:33:23.754 Socket sendto to 192.168.10.1:53857
error: Operation not permitted.
2026-01-28T10:33:23.956 UDP Client Rx (37) 192.168.10.255:5076
2026-01-28T10:33:23.956 Message [0xUDP Server Rx (37)
Message [0x3, v0x2] received from 192.168.10.1:53857 on 3, v0x2]
received from 192.168.10.1:53857 on 192.168.10.255:5076 : Search
request
0x00 000000192.168.10.255:5076 : 00 81000000Search
0x00 00000000 00000000 000000810000 .... ...0000 . .00000...
...00.
00 0x10 0000ff0000ff 0000000000 ...0. ..00 .. ...61d2. 0000..
00 ...... .... a... .
2026-01-28T10:33:24.024 Sending 49 bytes 0.0.0.0:38188 ->
192.168.10.1:53857.
2026-01-28T10:33:24.024 Socket sendto to 192.168.10.1:53857
2026-01-28T10:33:24.212 UDP Client Rx (37) 192.168.10.255:5076
2026-01-28T10:33:24.212 Message [0xUDP Server Rx (37)
Message [0x3, v0x3, v0x2] received from 192.168.10.1:53857 on
192.168.10.255:5076 : Search request2] received from
0x192.168.10.255:5076 : 00 00000000 810000Search
00 000x00 000000000000000 81000000 000000000 ....00000000
000000 ...00 ... .... ....
0x10 0000ffff.. . 0000..0000 61d20000 . ....0 .00 .....
0x10 0000ff0.. .... a... .
2026-01-28T10:33:24.334 Sending 49 bytes 0.0.0.0:38188 ->
192.168.10.1:53857.
2026-01-28T10:33:24.334 Socket sendto to 192.168.10.1:53857
I don't know why there is an operation not permitted error.
The firewall should be open:
root@iseg-iCS2-5230317:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Cheers,
Florian
On 1/28/26 02:40, Michael Davidsaver
wrote:
Hello Florian,
First, the usual questions. Which
versions of epics-base and associated modules are involved?
Including pvDataCPP, pvAccessCPP, and pva2pva if built as
separate modules. Do you set any of the EPICS_PVA*
environment variables?
On this MPOD crate. Is there only
the one IOC process? fyi. you can add '-p' to 'netstat' and
it will tell you which PID each socket is associated with.
As Andrew mentioned.
Setting $EPICS_PVA_DEBUG=3 will turn on a fire hose for
logging.
From the output provided, PVXS is
not present. You might also try "pvxlist" and/or "softIocPVX"
to see if the behavior differs.
On 1/27/26 4:02 AM, Florian
Feldbauer via Tech-talk wrote:
Hey
all,
I have a strange problem, that I haven't encountered before.
In our lab we have a small test setup for our pixel sensors.
As HV/LV power supply for these sensors we use a Wiener MPOD
crate with an iseg Crate Controller.
The crate controller is running Linux (The Ångström
Distribution v2017.12) and an EPICS IOC with PVA.
Now, when I run `pvlist` from another PC I see a list of all
the IOCs running in this network except the one on the iseg
Crate Controller.
When I explicitly run `pvlist iseg-iCS2-5230317` I get a list
of all PVs from that IOC, so PVA communication works in
general, but for some reason this IOC is not reacting on
broadcasts.
I checked with netstat and for me this looks correct:
-tuln | grep 5076
udp 0 0 224.0.0.128:5076 0.0.0.0:*
udp 0 0 192.168.10.255:5076 0.0.0.0:*
udp 0 0 192.168.10.22:5076 0.0.0.0:*
udp 0 0 :::50767 :::*
There is no firewall running on the crate controller.
Any idea what could cause this issue?
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
NB 2/131 / Fach 125
D-44801 Bochum
Office: NB 2/134
- Re: pvlist does not find all servers in network Michael Davidsaver via Tech-talk
- pvlist does not find all servers in network Florian Feldbauer via Tech-talk
- Re: pvlist does not find all servers in network Florian Feldbauer via Tech-talk
OmsAsyn Maxnet Homing Blomley, Edmund (IBPT) via Tech-talk
RE: OmsAsyn Maxnet Homing Pearson, Matthew via Tech-talk
2025
<2026>
2025
<2026>
