1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: udpiiu messages
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 29 Jan 2026 16:32:10 +0100
Mark,
which version of EPICS base is running on the IOC ?
(probably a useless question, since BASE 7.010 has the same message)
The short explenation is, that someone is sending rubbish
(in the EPICS ca sense) to an EPICS UDP port.
There is now way to turn that message off, to my knowledge, after
reading the code.
(I think that udpiiu is responsible for repeater business)
It would be nice to try to run a tshark/tcpdump to see what is going on.
HTH
/Torsten
On 2026-01-29 15:26, Mark Rivers via Tech-talk wrote:
Folks,
I am seeing error messages like this printed in the Linux shell periodically:
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.250:3956 ignored ../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.250:3956 ignored ../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.246:3956 ignored ../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.250:3956 ignored ../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.246:3956 ignored ../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.250:3956 ignored ../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.246:3956 ignored ../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.250:3956 ignored ../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.246:3956 ignored
The messages are being printed from udpiiu.cpp in EPICS base.  I believe they are generated by medm that is running in the background.  medm is built with base 7.0.7.
I believe port 3956 is used for GigEVision.  This suggests that the devices with those IP addresses could be cameras, but they are not registered in our DNS.  I am trying to track them down.
However, given that the messages appear to have nothing to do with EPICS, why is EPICS base printing an error message, rather than simply ignoring them?
What do these messages mean, and can they be turned off?
udpiiu messages Mark Rivers via Tech-talk
Prev: udpiiu messages Mark Rivers via Tech-talk
Next: RE: EPICS codeathon at Diamond Mercado, Ronaldo (DLSLtd, RAL, TEC) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: udpiiu messages Hill, Jeff via Tech-talk
