1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: udpiiu messages
From: "Hill, Jeff via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>, Mark Rivers <rivers at cars.uchicago.edu>
Date: Mon, 2 Feb 2026 19:10:47 +0000
This can pccur when one of the network switch or connected device are manually set to run at inconsistent ethernet clock rates...
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, January 29, 2026 7:26 AM
Subject: [EXTERNAL] udpiiu messages
Folks,
I am seeing error messages like this printed in the Linux shell periodically:
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.250:3956 ignored
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.246:3956 ignored
The messages are being printed from udpiiu.cpp in EPICS base.  I believe they are generated by medm that is running in the background.  medm is built with base 7.0.7.
I believe port 3956 is used for GigEVision.  This suggests that the devices with those IP addresses could be cameras, but they are not registered in our DNS.  I am trying to track them down.
However, given that the messages appear to have nothing to do with EPICS, why is EPICS base printing an error message, rather than simply ignoring them?
What do these messages mean, and can they be turned off?
Re: udpiiu messages Hill, Jeff via Tech-talk
udpiiu messages Mark Rivers via Tech-talk
Prev: Re: asynInt32 device support for mbbiDirect record for representing bitmasks Mark Rivers via Tech-talk
Next: Re: udpiiu messages Hill, Jeff via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: udpiiu messages Torsten Bögershausen via Tech-talk
