1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: udpiiu messages
From: "Hill, Jeff via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>, Mark Rivers <rivers at cars.uchicago.edu>
Date: Mon, 2 Feb 2026 19:56:01 +0000
The Ethernet, IP, and UDP checksums are not strong enough to detect situations where almost every byte in the message is damaged. This can cause even the UDP port field to arrive damaged.
The switch and attached device should be set for continuous auto-negotiation following modern practice.
Often this problem happens because the network device driver auto-negotiates only once when booting up, and perhaps the switch was not powered up at that time.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Hill, Jeff via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, February 2, 2026 12:10 PM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>; Mark Rivers <rivers at cars.uchicago.edu>
Subject: [EXTERNAL] Re: udpiiu messages
This can pccur when one of the network switch or connected device are manually set to run at inconsistent ethernet clock rates...
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, January 29, 2026 7:26 AM
Subject: [EXTERNAL] udpiiu messages
Folks,
I am seeing error messages like this printed in the Linux shell periodically:
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.250:3956 ignored
../udpiiu.cpp: Undecipherable (payload too small) UDP msg from 10.54.160.246:3956 ignored
The messages are being printed from udpiiu.cpp in EPICS base.  I believe they are generated by medm that is running in the background.  medm is built with base 7.0.7.
I believe port 3956 is used for GigEVision.  This suggests that the devices with those IP addresses could be cameras, but they are not registered in our DNS.  I am trying to track them down.
However, given that the messages appear to have nothing to do with EPICS, why is EPICS base printing an error message, rather than simply ignoring them?
What do these messages mean, and can they be turned off?
Re: udpiiu messages Hu, Yong via Tech-talk
udpiiu messages Mark Rivers via Tech-talk
Re: udpiiu messages Hill, Jeff via Tech-talk
Prev: Re: udpiiu messages Hill, Jeff via Tech-talk
Next: Re: MODBUS User-Defined Function Codes Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: udpiiu messages Hu, Yong via Tech-talk
