On 2026-02-02 18:54, William Jamieson via Tech-talk wrote:
Does anyone have experience using user-defined function codes alongside
the standard function codes that can be handled by the asyn MODBUS
driver? I am currently using the MODBUS driver for the standard 03 "READ
HOLDING REGISTERS" function while simultaneously using streamDevice
driver for executing user-defined functions. This is resulting in
conflicts between the MODBUS and streamDevice driver. I have tried
setting up two virtual ports pointing to the same serial port:
drvAsynSerialPortConfigure("rs485_modbus", "/dev/ttyUSB0", 0, 1, 0)
drvAsynSerialPortConfigure("rs485_stream", "/dev/ttyUSB0", 0, 1, 0)
I think that this is the wrong approach - according to my understanding.
Both the modbus and streamdevice should lock the asynport.
("rs485_port")
Which should the lock the underlying device, "/dev/ttyUSB0".
If you enable all asyn traces (and direct them to a file)
there should be some light comming up, if there is a problem
here in synchronizing things.
Or if there is a problem with the hardware ?
Then using a SEQ record that disables the rs485_modbus port then enables
the rs485_stream port before processing the stream record. after
processing, it disables the rs485_stream port and re-enables the
rs485_modbus port.
I disable and enable ports by writing a 0 (disable) or 1 (enable) to
the CNCT field of an ASYN record for each port. Example record:
record (asyn, "modbusPort_ASYN")
field (PORT, "rs485_modbus")
Not only does this switchover create a lot of I/O Error messages in the
IOC shell, but this still results in a garbled data readback from the
stream record.
Does anyone have a successful method of making these two methods work in
parallel? (or some other tools that make it work) Or should I just give
up and use deviceStream reads/writes instead of just the custom ones. I
prefer to use the MODBUS driver if possible for the standard MODBUS
function codes.
Thanks for any help!
William Jamieson
PPPL I&C Engineer
- Re: [External] Re: MODBUS User-Defined Function Codes William Jamieson via Tech-talk
- MODBUS User-Defined Function Codes William Jamieson via Tech-talk
Re: MODBUS User-Defined Function Codes Mark Rivers via Tech-talk
RE: EPICS Collaboration Meeting Spring 2026 - CEA IRFU Paris-Saclay GOUGNAUD Francoise via Tech-talk
2025
<2026>
2025
<2026>
