1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: control room operations accounts
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 6 Feb 2026 20:33:07 +0100
Similarly, ITER only allows personal accounts in the production control system.
As far as I understand, the roles are assigned via LDAP groups, which are understood by EPICS Access Security running on our CA and PVA Gateways. (The UAG may contain the name of an LDAP group, in which case being a member of that group will make you part of the UAG. LDAP follows the shift calendar.)
Console machines have fixed assignments to persons during a shift and are logged out and then logged in at turnover.
Cheers,
~Ralph
control room operations accounts Paul Sichta via Tech-talk
Prev: Re: Record TIME field taken from another record's VAL Torsten Bögershausen via Tech-talk
Next: String getting truncated across OUT link David Bracey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: control room operations accounts Paul Sichta via Tech-talk
