1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: How to send caPutLog logs to Grafana Loki
From: Anders Lindh Olsson via Tech-talk <tech-talk at aps.anl.gov>
To: Afonso Haruo Carnielli Mukai <afonso.mukai at lnls.br>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 10 Feb 2026 07:28:44 +0000
Hello Afonso,
We stream the putlog as well as procserv log, conserver log, etc. to Grafana Loki using syslog-ng. Look at our ansible role for IOC deployment and then for syslog-ng – I think you will be able to find those in our GitLab instance. I do, unfortunately, not know how Grafana Loki is configured after this; I am pretty sure Promtail used to be involved but I do not know if it is anymore. The latter parts – closer to Grafana loki and graylog – are managed by our IT or infrastructure group(s), but maybe you can reach out to some names you know there?
HTH
A
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Afonso Haruo Carnielli Mukai via Tech-talk <tech-talk at aps.anl.gov>
Date: Monday, 9 February 2026 at 19:54
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: How to send caPutLog logs to Grafana Loki
I'm working on a proof of concept for sending IOC PV put logs to a logging server using caPutLog and Grafana Loki. I'm new to Loki, but my understanding is that it only accepts logs via the HTTP API, different from something like Graylog where you can configure inputs in different formats.
Is anyone using caPutLog and Loki? If so, how do you forward the logs to the server? After some discussions with people working with EPICS here, I can think of the following options:
1. Implement client-side code on the IOC to send directly to Loki (seems to be more work than the other options)
2. Implement a simple server that receives the logs from caPutLog and sends it to Loki
3. (Not sure caPutLog supports this) Get the IOC logs to the system journal/container logs (the IOCs in question are containerised) and then use Grafana Alloy to send them to Loki - is it possible to configure caPutLog to just print the logs to the console, without setting a server?
If anyone has experience or thoughts on this, comments and suggestions are appreciated.
Best regards,
Afonso Mukai
Brazilian Synchrotron Light Laboratory
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
How to send caPutLog logs to Grafana Loki Afonso Haruo Carnielli Mukai via Tech-talk
Prev: Re: Base 7.0.10 was released ? Han Lee via Tech-talk
Next: Re: Support for piezo controller nanoFAKTUR EBD-060310 LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: How to send caPutLog logs to Grafana Loki Afonso Haruo Carnielli Mukai via Tech-talk
Next: RE: How to send caPutLog logs to Grafana Loki Afonso Haruo Carnielli Mukai via Tech-talk
