1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: How to send caPutLog logs to Grafana Loki
From: Afonso Haruo Carnielli Mukai via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 9 Feb 2026 17:44:19 +0000
I'm working on a proof of concept for sending IOC PV put logs to a logging server using caPutLog and Grafana Loki. I'm new to Loki, but my understanding is that it only accepts logs via the HTTP API, different from something like Graylog where you can configure inputs in different formats.
Is anyone using caPutLog and Loki? If so, how do you forward the logs to the server? After some discussions with people working with EPICS here, I can think of the following options:
1. Implement client-side code on the IOC to send directly to Loki (seems to be more work than the other options)
2. Implement a simple server that receives the logs from caPutLog and sends it to Loki
3. (Not sure caPutLog supports this) Get the IOC logs to the system journal/container logs (the IOCs in question are containerised) and then use Grafana Alloy to send them to Loki - is it possible to configure caPutLog to just print the logs to the console, without setting a server?
If anyone has experience or thoughts on this, comments and suggestions are appreciated.
Best regards,
Afonso Mukai
Brazilian Synchrotron Light Laboratory
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: How to send caPutLog logs to Grafana Loki Anders Lindh Olsson via Tech-talk
Prev: Re: Questions on EPICS 7 NT types and CA → PVAccess migration Simon Rose via Tech-talk
Next: Re: [Ext]RE: Help with continuous oscillation of a motor Jesse Hopkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Yes, Base 7.0.10 was released! Han Lee via Tech-talk
Next: Re: How to send caPutLog logs to Grafana Loki Anders Lindh Olsson via Tech-talk
