1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: phoebus byte-monitor and accessibility
From: Pierrick Hanlet via Tech-talk <tech-talk at aps.anl.gov>
To: "Pearson, Matthew" <pearsonmr at ornl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 13 Feb 2026 18:45:22 +0000
Thanks Matt,
Perhaps I'll make a feature request.
Cheers,
Pierrick
On 2/13/26 12:39, Pearson, Matthew wrote:
[EXTERNAL] – This message is from an external sender
Not exactly what you want, but there are the bit labels you can add. Those are static text, but I think it’s possible to modify the text via a rule or a script.
Or, an ugly way to do this is to overlay the text on the widget, and use visibility rules on the text.
For the LED widgets there is a built in way to do this. I guess it would be useful for the byte monitor too.
Or, perhaps lay out normal LED widgets side-by-side, so it looks like a byte monitor.
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Pierrick Hanlet via Tech-talk
Sent: Friday, February 13, 2026 1:29 PM
To: tech-talk at aps.anl.gov
Subject: [EXTERNAL] phoebus byte-monitor and accessibility
Greetings all, I'd like to display 0/1 in each bit of the byte monitor widget for accessibility reasons. Is there a way to do this? Thank you, Pierrick -- Pierrick Hanlet Fermi National Accelerator Accelerator Front End Controls +1-630-840-5555
Greetings all,
Thank you,
Pierrick
Pierrick Hanlet
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Pierrick Hanlet
RE: phoebus byte-monitor and accessibility Pearson, Matthew via Tech-talk
phoebus byte-monitor and accessibility Pierrick Hanlet via Tech-talk
Prev: RE: phoebus byte-monitor and accessibility Pearson, Matthew via Tech-talk
Next: RE: phoebus byte-monitor and accessibility Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
