Hi All,
Just started having a look at EPICS and I feel at the first hurdle...
As far as I can see, I followed the instructions on the presentation at
https://epics.anl.gov/docs/GSWE/iocs/IOC_Overview.ppt .
All worked well and as far as I can see all the files were generated.
When I tried to use st.cmd after turning it into a command using chmod
-x st.cmd, it tells me command not found.
I bet this is a very simple issue, but I can't figure it out.
I'm on a Rocky 9 VM and if I do softIoc that works fine.
Any advice welcomed.
Thank you.
Kind Regards
Luis
Luis Moreira
EPFL SB SPC-II, PPH241 (Batiment PPH) Station 13
CH-1015 Lausanne, Switzerland
Tel. (+41) 21 693 58 37
E-Mail luis.moreira at epfl.ch
- Re: first time with EPICS: st.cmd doesn't work Heinz Junkes via Tech-talk
Re: Does every DB record need to produce a PV? bob dalesio via Tech-talk
2025
<2026>
Nested MSI and Makefile dependencies Michael Davidsaver via Tech-talk
2025
<2026>
