1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: first time with EPICS: st.cmd doesn't work
From: Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov>
To: Luis Alberto De Sousa Moreira <luis.moreira at epfl.ch>
Cc: tech-talk at aps.anl.gov
Date: Tue, 17 Feb 2026 16:32:18 +0100
just try “./st.cmd”
Heinz
> On 17. Feb 2026, at 16:19, Luis Alberto De Sousa Moreira via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hi All,
> Just started having a look at EPICS and I feel at the first hurdle...
> As far as I can see, I followed the instructions on the presentation  at https://epics.anl.gov/docs/GSWE/iocs/IOC_Overview.ppt .
> All worked well and as far as I can see all the files were generated. When I tried to use st.cmd after turning it into a command using chmod -x st.cmd, it tells me command not found.
> I bet this is a very simple issue, but I can't figure it out.
> I'm on a Rocky 9 VM and if I do softIoc that works fine.
> Any advice welcomed.
> Thank you.
> Kind Regards
>                 Luis
> Luis Moreira
> EPFL SB SPC-II, PPH241 (Batiment PPH) Station 13
> CH-1015 Lausanne, Switzerland
> Tel.    (+41) 21 693 58 37
> E-Mail  luis.moreira at epfl.ch
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: first time with EPICS: st.cmd doesn't work Luis Alberto De Sousa Moreira via Tech-talk
Prev: first time with EPICS: st.cmd doesn't work Luis Alberto De Sousa Moreira via Tech-talk
Next: Re: first time with EPICS: st.cmd doesn't work Luis Alberto De Sousa Moreira via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
