Hi folks,
Due to an issue with our newer Eiger2 detector I recently had to put an older Pilatus3 back into service at the beamline. It’s been a couple of years since we used it. I built a new IOC for it (as the previous IOC was quite old), using a version of AreaDetector
and ADPilatus that was current as of May 2025. This is all running on EPICS base 7.0.9. Camserver version is 7.9.2.
I’m running into an issue where sometimes at the end of data collection the IOC hangs in a state where it thinks it is still collecting data. Camserver shows data collection is done. The images are in the expected data directory and that data directory is visible
to the IOC. I think it’s an issue with the IOC not reading the images, as the image counter doesn’t seem to update during these exposures where it hangs. I’ve attached a screenshot that shows this issue (due to size limitations a second screenshot is not included
that shows the same AD window along with a terminal window showing that the images exist in the expected location).
I should mention there are times when it finishes okay, but once it gets in this state of hanging at the end of data collection it seems to keep doing that until I restart the IOC (not tested too heavily).
I don’t see any obvious errors in the IOC. While it’s waiting for trigger it gets a timeout on what looks like a status query, and when I kill it the IOC reports an unexpected response:
2026/02/11 16:57:07.184 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes
2026/02/11 17:14:34.698 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=13 ERR kill
Any thoughts on what might be going on here? I know that I could force the exposure to abort by setting the DelayTime shorter, but often we have 2-10 minutes between arming and actual triggering of the detector and so I want
that to be sufficiently long that it wouldn’t abort in the middle of an exposure sequence if it didn’t see the images.
All the best.
---- Sector 18, Advanced Photon Source Research Associate Professor, Illinois Tech Attachment:
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
