1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: first time with EPICS: st.cmd doesn't work
From: Luis Alberto De Sousa Moreira via Tech-talk <tech-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: tech-talk at aps.anl.gov
Date: Tue, 17 Feb 2026 16:54:19 +0100
Hi Heinz,
Apologies, I must have done something strange the first time I've tried it... at the second attempt it worked fine. It then told me the next issue, which was that I left the exclamation sign on the file path on the first line of the st.cmd file.
I changed that and now I get the Epics> prompt.
Thank you for the help.
Kind Regards
                   Luis
On 17/02/2026 16:38, Luis Alberto De Sousa Moreira via Tech-talk wrote:
Hi Heinz,
Thank you for replying.
It didn't work.
Kind Regards
               Luis
On 17/02/2026 16:32, Heinz Junkes wrote:
just try “./st.cmd”
Heinz
On 17. Feb 2026, at 16:19, Luis Alberto De Sousa Moreira via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi All,
Just started having a look at EPICS and I feel at the first hurdle...
As far as I can see, I followed the instructions on the presentation  at https://epics.anl.gov/docs/GSWE/iocs/IOC_Overview.ppt   . All worked well and as far as I can see all the files were generated. When I tried to use st.cmd after turning it into a command using chmod -x st.cmd, it tells me command not found.
I bet this is a very simple issue, but I can't figure it out.
I'm on a Rocky 9 VM and if I do softIoc that works fine.
Any advice welcomed.
Thank you.
Kind Regards
                 Luis
Luis Moreira
EPFL SB SPC-II, PPH241 (Batiment PPH) Station 13
CH-1015 Lausanne, Switzerland
Tel.    (+41) 21 693 58 37
E-Mail  luis.moreira at epfl.ch
Luis Moreira
first time with EPICS: st.cmd doesn't work Luis Alberto De Sousa Moreira via Tech-talk
Re: first time with EPICS: st.cmd doesn't work Heinz Junkes via Tech-talk
Re: first time with EPICS: st.cmd doesn't work Luis Alberto De Sousa Moreira via Tech-talk
Prev: Re: first time with EPICS: st.cmd doesn't work Luis Alberto De Sousa Moreira via Tech-talk
Next: ADPilatus hangs after data collection completes Jesse Hopkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
