1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Does every DB record need to produce a PV?
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 17 Feb 2026 20:00:25 +0100
On Tue, 17 Feb 2026 at 19:54, Johnson, Andrew N. via Tech-talk <tech-talk at aps.anl.gov> wrote:
... EPICS IOCs since 3.15 have supported server-side filters that let the client append parameterized channel filters to the PV name as well.
Completely forgot that, of course!
Given that some of these filters take numbers as configuration parameters, every single record provides an unlimited number of PVs.
(When you use record name aliases, even more ... ;-)
Cheers,
~Ralph
Does every DB record need to produce a PV? David Bracey via Tech-talk
Re: Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Re: Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: Does every DB record need to produce a PV? David Bracey via Tech-talk
Re: Does every DB record need to produce a PV? Johnson, Andrew N. via Tech-talk
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Does every DB record need to produce a PV? Johnson, Andrew N. via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Hartman, Steven via Tech-talk
