1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] Does every DB record need to produce a PV?
From: "Hartman, Steven via Tech-talk" <tech-talk at aps.anl.gov>
To: "Sukhanov, Andrei" <sukhanov at bnl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 17 Feb 2026 23:48:38 +0000
From my perspective, an EPICS IOC with ~2000 PVs lacking descriptions, for a device without a Programmer’s Manual, is unmanageable.
Perhaps. But no more unmanageable than receiving a custom CA or PVA server application implementing similar functionality as that IOC, also without proper documentation.
Actually, the IOC may well be preferable. At least with the IOC, much of the functionality is well defined: scan logic, interface to device support, internal / external interfaces to other PVs, alarm configuration, alarm status and severity, high/low set point limits, ability to query input and output configuration, error reporting, time stamps, and lots of other capabilities that may or may not be implemented in the non-IOC implementation. Plus it is using well tested code with resources for support if needed.
Steven Hartman
hartmansm at ornl.gov
Does every DB record need to produce a PV? David Bracey via Tech-talk
Re: Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Re: Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Hartman, Steven via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Nariyoshi, Pedro via Tech-talk
