1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: ecat2 module
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Konrad Gajewski <konrad.gajewski at physics.uu.se>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 18 Feb 2026 11:24:46 +0100
Hej Konrad,
Did you check with the author ?
There doesn't seem to be much activity.
(And what does "doesn't work" mean ?
Do you want to share more information  ?)
I may put in some advertisment for ecmc here:
https://urldefense.us/v3/__https://github.com/epics-modules/ecmc__;!!G_uCfscf7eWS!fWYMCGpFeXpmbYkNbYV3UoRKVLkACk19CCfD4aNCLkkceaUU3fGTojnkcrETl5x1eBM-C3yQJK_903mttSI$ (The readme says Motion...and Generic IO)
If you don't need motion, you can still use it for IO.
Please let use know, what you think.
/Torsten
On 2026-02-16 10:35, Konrad Gajewski via Tech-talk wrote:
Hello,
Does anybody have ecat2 module working with IgH EtherCAT Master for Linux v 1.6.8 and Epics base7.0.x?
I've started to patch the module found at https://urldefense.us/v3/__https://github.com/__;!!G_uCfscf7eWS!fWYMCGpFeXpmbYkNbYV3UoRKVLkACk19CCfD4aNCLkkceaUU3fGTojnkcrETl5x1eBM-C3yQJK_9DyN2wv0$ paulscherrerinstitute/ecat2 and it compiles without errors but it doesn't work in the IOC. Before I put more effort to fix it I'd like to check if it's not already done.
Best regards,
Konrad
ecat2 module Konrad Gajewski via Tech-talk
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Anders Lindh Olsson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: ecat2 module Konrad Gajewski via Tech-talk
Next: Does every DB record need to produce a PV? David Bracey via Tech-talk
