1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] Does every DB record need to produce a PV?
From: Anders Lindh Olsson via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>, Ralph Lange <ralph.lange at gmx.de>
Date: Wed, 18 Feb 2026 10:43:06 +0000
> Do other sites using the Channel Finder have similar issues with internal PVs being included in its PV name database and making it harder to identify the public ones? Do you filter out the internal PVs at all?
We do not have any real issues at ESS, with ca 14 million between production and lab networks, all in ChannelFinder. We have talked about filtering out internal PVs but do not and most likely will not. We instead just mark the internal ones (using a pound symbol in the record names).
Cheers
A
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Sent: 18 February 2026 09:48
On Tue, 17 Feb 2026 at 20:19, Sukhanov, Andrei via Tech-talk <tech-talk at aps.anl.gov> wrote:
From my perspective, an EPICS IOC with ~2000 PVs lacking descriptions, for a device without a Programmer’s Manual, is unmanageable.
Certainly. I completely agree. I've come across such things, and they're a pain.
But that's bad application quality, which is a different thing.
Like reading a bad book, which can be a painful experience. Where I don't think Microsoft Word (the tool they used) nor Merriam Webster (where they got the words from) is at fault.
Of course, nowadays, AI can write wonderful books. Amazon's ebooks section is full of them.
Cheers,
~Ralph
RE: [EXTERNAL] Does every DB record need to produce a PV? Pearson, Matthew via Tech-talk
Does every DB record need to produce a PV? David Bracey via Tech-talk
Re: Does every DB record need to produce a PV? Mark Rivers via Tech-talk
Re: Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Hartman, Steven via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Sukhanov, Andrei via Tech-talk
Re: [EXTERNAL] Does every DB record need to produce a PV? Ralph Lange via Tech-talk
Prev: Re: ecat2 module Torsten Bögershausen via Tech-talk
Next: Re: [EXTERNAL] Does every DB record need to produce a PV? Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: [EXTERNAL] Does every DB record need to produce a PV? Ralph Lange via Tech-talk
Next: RE: [EXTERNAL] Does every DB record need to produce a PV? Pearson, Matthew via Tech-talk
