1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Help in debugging ACF connection issue
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Érico Nogueira Rolim <erico.rolim at lnls.br>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 24 Feb 2026 10:02:26 +0000
On 2/23/26 3:36 PM, Érico Nogueira Rolim via Tech-talk wrote:
Hi, all!
We have had some occasional issues when rebooting servers in our BPM
infrastructure, and I'd like to request guidance on how to best debug it.
We have an IOC for each RF front-end and an IOC for the actual BPM
board, and we have an Access Security rule to block writes to certain
front-end PVs when the fast orbit distortion detection is enabled in the
BPM board.
Sometimes, when these servers are rebooted, the front-end IOC
is unable to connect to the PV from the BPM board IOC
So it never connects at all?  Odd.
While writing this email, I thought of adding a proxy record in the
front-end DB that connects to the outside PV, and checking the
connection on that. Should it yield different results? Is the connection
path considerably different between DB links and AS links?
This seems an interesting test.  The asCa code [1] creates a separate CA client context to what the dbCa code (aka. CA_LINK) uses [2].  Both should use the same configuration from the environment, and so should yield the same result.
https ://github.com/epics-base/epics-base/blob/3855356d2faef8ccf67ae5d0a368d44ef2527a5c/modules/database/src/ioc/as/asCa.c#L172-L173
https ://github.com/epics-base/epics-base/blob/3855356d2faef8ccf67ae5d0a368d44ef2527a5c/modules/database/src/ioc/db/dbCa.c#L1108-L1109
Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Prev: Open positions in Controls @ PSI Celcer, Tine via Tech-talk
Next: IOC showing out errors in call SNMP functions on linux-x86_64 Varuna Crishan Meddage via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Next: Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
