1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Help in debugging ACF connection issue
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 23 Feb 2026 15:36:29 +0000
Hi, all!
We have had some occasional issues when rebooting servers in our BPM
infrastructure, and I'd like to request guidance on how to best debug it.
We have an IOC for each RF front-end and an IOC for the actual BPM
board, and we have an Access Security rule to block writes to certain
front-end PVs when the fast orbit distortion detection is enabled in the
BPM board. Sometimes, when these servers are rebooted, the front-end IOC
is unable to connect to the PV from the BPM board IOC (verified using
the ascar command), and (correctly) blocks writes to the relevant PVs.
If I restart the front-end IOC, it immediately connects to the board
IOC. The front-end IOC comes up faster than the board IOC, since it
doesn't require as much setup and has fewer records to process at
initialization.
I have already tried reproducing this outside of reboots, and waiting a
long time between starting the front-end IOC and the board IOC, but it
has always established a connection immediately. What could be causing
the issue we observe? These IOCs are running on the same server, though
our EPICS_CA_ADDR_LIST is empty because we rely on broadcasts for this
subnet.
While writing this email, I thought of adding a proxy record in the
front-end DB that connects to the outside PV, and checking the
connection on that. Should it yield different results? Is the connection
path considerably different between DB links and AS links?
Cheers,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
Prev: IR cameras Wang, SuYin Grass via Tech-talk
Next: Collaboration on use of EPICS for engine rig control (Single-Cylinder Engine Test Cell at Chalmers University Of Technology in Gothenburg) Djordje Purkovic via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: IR cameras Mark Rivers via Tech-talk
Next: Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
ANJ, 24 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
